Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 22nd September 2003, 10:22 AM   #1
Sjef is offline Sjef  Netherlands
Default Digital in on CD player
Does anyone have any experience with building a digital input into a CD player ??
My player (a marantz CD63) has got a digital output. I have experimented with a digital equalizer for a couple of days and really like what it can do to my system. You loose some sound quality but can gain a lot at the same time.
Bass quality improves a lot and the midrange becomes much more coherent but it looses some of the atmospere and imaging however.
The problem is that the DA converter and/or analog output stage in the EQ (Behringer DEQ2496) isn't half as good as the heavily modified DAC in the Marantz player itself. I would like to know if it's possible to put the digital out of the EQ back into the players DAC ??
Old 22nd September 2003, 12:18 PM   #2
A 8 is offline A 8  Sweden
You would need a reciever chip like the CS8412/14 and some switching logic to re-route the clock and datalines.
Perhaps it would be better to build an outboard dac.
Old 22nd September 2003, 12:30 PM   #3
I expected that answer, but I don't want to build a seperate DAC. To build a seperate DAC (I heard lot's of them) that sound equal or better than the modified Marantz DAC would cost me a lot of money and trouble. Besides, I don't want an extra box. The CD player allready has it's own seperate powersupply and I really don't want to end up with a three box CD player.
Somehow it should be possible to build in a digital insert in the player. Anyone ??
Old 22nd September 2003, 03:38 PM   #4
guido is offline guido  Netherlands
guido's Avatar
Check out the chipset first!
I'm not shure (!), but i think it uses a decoder chip with dig filter inside. This would mean that you need more than the receiver, u also need a dig. filter to feed the DAC with oversampled data.
Greetings,
GuidoB
GuidoB
Old 22nd September 2003, 06:24 PM   #5
Default Re: Digital in on CD player
You will need to know the location of the clock and data lines of the dac chip in the CD63 (SM5872?) at the very least. Having cut the connection to dac, you can either add a SPDIF transmitter and receiver or keep the clock and data lines apart and buffer then before sending them the EQ but this will require modification in the EQ. With a bit of added logic you can set things up in such a way that the internal path is automatically re-established when there is no incoming SPDIF signal.
ray.
Adding digital out to a CD player with only PCM! Destroyer OS. Parts 0 4th June 2006 09:51 PM
Digital out from a CD player that doenst have one? crackerkorean Digital Source 5 19th January 2006 05:26 PM
How to add digital out to old CD player? bachiano Digital Source 4 15th November 2005 02:35 PM
Digital out from factory car CD player bknauss Digital Source 3 25th January 2004 07:06 AM
NAD 522 CD Player Digital Out Mod - HELP! Jonathan M Digital Source 11 18th April 2003 07:25 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
