| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#11 |
#12 |
#13 |
You have three OpAmps per EACH channel there. Converters seem to be 503 and 603.
#14 | |
Is this a good solution? Or tell me another. And sorry for my ignorance in electronics. I need to improve the sound of my beloved XA3ES. |
#15 |
I would endorse the OPA2604 recommendation for this player for replacing all the 5532's.
The AD627... no way. Thats a micropower opamp totally unsuited to audio. Slew rate 0.05V/us
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#16 |
IŽll go for OPA2604. I hope to find the softness and sweetness I want. The CD match with Audiolab 8000S amplifier and B&W CDM1SE speakers.
#17 |
I did try them. Not very happy about them, after that I switched to LM4562...
Do what I did - use some good quality sockets first to try different variants. When you settle for one, you can eventually remove the sockets. |
#18 |
Again I doubt arise. LM4562 or OPA2134.
I'm going crazy. At the end buy a new player. |
#19 |
Before You replace the op amps there are other mods you could try.
I have not found a schematic (that I could download for free)! But looking at your photo has the CD player output stage seems to have muting transistors. If they are muting transisitors they will probably be positioned in the circuit to pull down the outputs. If so, these usually can be removed. You could probably also remove any DC blocking capacitors if you check that there are no excessive DC offsets.
#20 | |
![]() The OPA2604 is the one to go for if you want the most "analogue and non fatiguing" sound. The OPA2134 is less coloured but we are talking subtleties. Either should easily better the 5532's fitted. I havn't evaluated the LM4562 so can't comment on that one. For what these parts cost and the few minutes it takes to swap them I can't see the problem tbh
| Sony CDP 68 or CDP 750 Clone | searchlight | Digital Source | 1 | 7th December 2010 08:27 PM |
| Replacing NE5532 Op-Amps with AD827? | KevinLee | Solid State | 5 | 12th June 2010 05:24 AM |
| Sony CDP-D500 & CDP-2700 | audiobot | Digital Source | 2 | 20th December 2009 11:44 AM |
| Sony CDP-337ESD v Sony CDP-X33ES which is best? | eldarvanyar | Digital Source | 0 | 10th January 2008 11:04 AM |
| WTB: SONY CDP-X3000ES or CDP-X5000ES | cartman | Swap Meet | 0 | 18th April 2007 06:16 PM |
