Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 29th January 2012, 01:38 PM   #11
kp93300 is offline kp93300  Malaysia
Hi Felipe,
Thanks for the answer. Very helpful advice that I will follow. I want to keep the XO on the board.
SQ stands for sound quality.
I have tried different types of ground without avail.
kp93300
Old 29th January 2012, 02:03 PM   #12
merlin el mago's Avatar
You must keep the digital ground coming from USB.
Old 29th January 2012, 02:55 PM   #13
Definitely you have grounding issues. Messing with the regulators won't solve that.
You need an USB cable with all four wires, even if you use separated PS, just to connect the grounds (PC with receiver).
Use coax cable on SPDIF or shielded CAT5 if you use I2S (use the shield to connect grounds). You could also try normal CAT5E with one grounding wire taped close on it's surface.
SPDIF S/P-DIF DOBM resp. Digital Input Selector include USB-SPDIF Converter tiefbassuebertr Digital Source 6 21st February 2012 08:00 PM
USB to SPDIF Converter mp006ltk Digital Source 13 15th September 2011 04:03 AM
Native 24bit 96k USB to Spdif I2S Converter Module DAC julcat Digital Line Level 11 3rd September 2010 12:59 PM
FS:USB-SPDIF/I2S Converter $45 bbp Swap Meet 13 7th February 2010 12:55 AM
Another USB to SPDIF converter Kane Williams Digital Line Level 0 10th October 2008 10:25 PM
Page generated in 0.07658 seconds (71.59% PHP - 28.41% MySQL) with 11 queries
