Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 19th January 2012, 02:37 PM   #1
Default DAC Hifidiy Olympic PCM1798 assembly and problem
Hi, from Argentina, i speak english not very well, im sorry
I have bought a Kit - DAC Hifidiy PCM1798 olympic version -
Someone has tried this kit ?
the kit comes with manual very synthesized
I dont understand a transformer volts,
Schematic Transformer:
i have connected to 220v : >>
when i connect to 220V, a Transformer make noise, a tube lights but... strong light... in 10 seconds a fuse cute and transformer burn,,smoke mell
Hifidiy say: " yes , it can work with 220V , the transformer is from 110 to 220V , I think may be you can check the attachment about the connection , may be you made a mistake , connect the wrong line , please check , anything can contact me, "
The DAC worked 10 seconds ,, but then see smoke.
The connection transformers its ok ?
Thank you and im sorry. I have another picture large.
Old 19th January 2012, 04:53 PM   #2
You need to connect BOTH of the 115V in SERIES WITH PROPER POLARITY. They have a "beginning" and an "end".
The way you connected the transformer damaged it - you applied 220V on just one 115V coil!
And you did solder in short-circuit the second coil - that is even worse for the transformer!!!
Connection should be something like RED - BLACk on 220V and BLUE - GREEN toghether. Altough, I am not sure if that's the proper polarity, it could be RED-GREEN to 220V and BLUE-BLACK toghether.
Vendor SHOULD tell you the correct connection for 220V (one of the two above), because only him knows the way the windings are polarized.
Old 19th January 2012, 05:09 PM   #3
Thank you Sonic!
please, could you draw me a pic please ?
you can try with paint.
im thinking about what to do now ?
a transformer burned...and a PCB components
maybe burned many components ?
maybe i can try with another kit (without chassis) u$150 , transformer u$25
or i can send to China Manufacture my kits without chassis
for u$50 shipping and they can check my kit burned and then u$50+ for shipping return to argentina?
Old 19th January 2012, 06:06 PM   #4
Components are probably all right... You can try buying another transformer from the same guys (with proper schematics how to connect). Or rewind (rebobinar) this one. I am sure you have shops that can do that there.
Old 20th January 2012, 01:24 PM   #5
Mayday is offline Mayday  Sweden
Could you post a better picture of the label on the transformer?
Windings are usually marked with a dot or something to show polarity.
The more you learn, the more you realize how little you know...
Mayday DIY blogg
Old 20th January 2012, 05:50 PM   #6
Old 20th January 2012, 06:00 PM   #7
From what I can see, blue and green should go to mains, and black and red soldered together.
Mayday DIY blogg
Old 20th January 2012, 06:11 PM   #8
sure ? many friends say in serie:
Red + Black >>>> 220V
(Blue + greend solded)
Old 20th January 2012, 06:51 PM   #9
syklab is offline syklab  Hong Kong
According to the chinese label on the RCore:
P1 Red. -Blue
P2 Greed.- Black
Looks like you should connect Blue and Green together
the Red and Black connect to your main AC inlet.
Old 20th January 2012, 06:58 PM   #10
Sorry, might have gotten it backwards.
I believe syklab is correct.
Mayday DIY blogg
Any experiences with the hifidiy pcm1794 dac? Sveinung Digital Line Level 8 5th May 2011 09:05 PM
Big Dac Board transformers and PCM1798 for sale sendler Swap Meet 3 27th February 2011 03:02 PM
FS: PCM1798 24-bit 192kHz DAC IC (25pcs) theAnonymous1 Swap Meet 1 12th November 2010 01:43 PM
HIFIDIY.net PCM1798 USB DAC with Tube Buffer bongoman Digital Source 22 30th December 2009 01:12 PM
HIFIDIY Assembly Instrctions download HIFIDIY Vendor's Bazaar 0 13th October 2009 04:00 AM
Page generated in 0.11426 seconds (84.36% PHP - 15.64% MySQL) with 10 queries
