| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#31 |
Don't know what could cause it, but I wouldn't play it on those nice speakers before I knew it was harmless. Have you measured the DC on DAC outputs? That is from signal to gnd? example right signal to right gnd etc.
#32 |
#33 |
a volume is normal compared to my cd player.
#34 |
You are measuring AC in the picture, not DC.
To be honest I'm not 100% sure I remember the "maximum" value, but it should be below 10mV I THINK. Someone might step in here, because I'm not sure that I remember correctly. |
#35 |
I have only just started learning about tubes. COULD the problem come from the tube picking up interference from something? Transformer or something like that?
Is everything grounded as the instructions say? |
#36 |
i have found a problem
![]() a problem is with 1 USB IN from my old pc ![]() now a USB DAC works veryyy smooth |
#37 |
Great
![]() Sometimes we get lucky and the problems are easily solved
#38 |
I personally strongly not recommend that using this device on USB connection mode.This pcb was designed for people who wanna listen to hi-resolution music,so the coxial connecter should be used.
The tube 6N11 equivalent to ECC88 or 6922,but please keep this tube in hand even replaced by some expensive tubes like Mullard or Telefonken.Only a few 6N11 tubes you can find in China. |
#39 |
Hi, ask: If i want improve my DAC, which components can be modified ? 2 Caps Bennic ?
A Kit comes with 2 Bennic, i see, this caps are chips. And whats about Crystal 1ppm and Dac 1794 ? (i can replace a Crystal 3ppm default and 1798 , this upgrade - crystal - dac is really better in a quality sound ? or with 2 caps Mundorf i can improve more ? thanlk you |
| Any experiences with the hifidiy pcm1794 dac? | Sveinung | Digital Line Level | 8 | 5th May 2011 09:05 PM |
| Big Dac Board transformers and PCM1798 for sale | sendler | Swap Meet | 3 | 27th February 2011 03:02 PM |
| FS: PCM1798 24-bit 192kHz DAC IC (25pcs) | theAnonymous1 | Swap Meet | 1 | 12th November 2010 01:43 PM |
| HIFIDIY.net PCM1798 USB DAC with Tube Buffer | bongoman | Digital Source | 22 | 30th December 2009 01:12 PM |
| HIFIDIY Assembly Instrctions download | HIFIDIY | Vendor's Bazaar | 0 | 13th October 2009 04:00 AM |
| Page generated in 0.09384 seconds (75.35% PHP - 24.65% MySQL) with 10 queries |
