DAC Hifidiy Olympic PCM1798 assembly and problem - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 20th January 2012, 08:20 PM   #11
ok now i need order a new transformer to china.
Ask: in the most cases, when transformer burn and fuse cut,
a PCB components continue working ?
i dont know if buy a new kit or only transformer with new tube.
Old 20th January 2012, 09:59 PM   #12
and another questions, when i bought a kit to China, i asked them to weld small pieces.
Im seeing now, many welds touch with the next leg. this is normal ? or not is a problem ?
pic:
Old 20th January 2012, 10:05 PM   #13
Mayday is offline Mayday  Sweden
pic:
Look at the datasheets for those IC's, there you'll see which if any pins should connect.
But that does look sloppy.
The more you learn, the more you realize how little you know...
Old 20th January 2012, 10:54 PM   #14
Old 20th January 2012, 11:13 PM   #15
Look for your self, the dot on the IC is by pin1, CKSEL in the pin description.
Old 20th January 2012, 11:18 PM   #16
im sorry, i dont understand , welding is fine ?
Old 20th January 2012, 11:24 PM   #17
I don't know if it's on purpose.
Pin13 and 14 are connected, that's Uout and Cout.
Pin24, 25 and 26 are connected, that's VDD, SCKO and FSOUTI.
I really can't tell if they are to be connected like that with solder.
I suggest you e-mail and ask the seller.
Old 20th January 2012, 11:25 PM   #18
I'm new at digital IC's so DON'T take my word as gospel!
Old 20th January 2012, 11:25 PM   #19
ok thank you Mayday
Old 20th January 2012, 11:33 PM   #20
The Welding is fine mati
Welding is a better word for soldering - much more more manly.
From now on ....I'll call it welding.
I am a welder
...and I have had a drink - like New Years eve again
Happy new year
Any experiences with the hifidiy pcm1794 dac? Sveinung Digital Line Level 9 7th September 2015 11:50 AM
HIFIDIY.net PCM1798 USB DAC with Tube Buffer bongoman Digital Source 24 9th May 2014 02:16 PM
Big Dac Board transformers and PCM1798 for sale sendler Swap Meet 3 27th February 2011 04:02 PM
FS: PCM1798 24-bit 192kHz DAC IC (25pcs) theAnonymous1 Swap Meet 1 12th November 2010 02:43 PM
HIFIDIY Assembly Instrctions download HIFIDIY Vendor's Bazaar 0 13th October 2009 05:00 AM
Copyright 1999-2017 diyAudio
