Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
High Performance WM8741 Upsampling DAC New Version build thread (show 'n tell too)
Old 21st April 2012, 08:15 AM   #341
Turbon is offline Turbon  Sweden
Turbon's Avatar
Feel free to upload your code so we can have a look at it.
Brgds
Old 21st April 2012, 02:40 PM   #342
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Old 21st April 2012, 05:25 PM   #343
TheGimp's Avatar
I got the code working and can receive IR characters with both the Sony and Rosewill (RC6) remote controls. If I can find a couple of the other remote controls that are supposed to be supported, I'll test them as well. Since it works with SONY and RC6, I feel the rest of the remotes will work as well.
Once I figure out how to strip the toggle bit from the RC6, get it decoding properly, and clean up all the patches I'll post the code.
Although it might be best to wait until I get the proper 20X4 display and revert to that code instead of the current 16X4 display code.
I have to go cut the lawn before it rains right now.
Old 23rd April 2012, 03:43 PM   #344
TheGimp's Avatar
Volume up, Volume down, Mute ( was Dim) work, but once a button is pushed the system acts as if the button is held down and never let up.
Pressing another unused key stops it.
code attached has one untested change in it to disable and re-enable the interrupt.
Old 25th April 2012, 07:50 PM   #345
TheGimp's Avatar
Code is now functioning with a Sony TV Remote (no part number I could find) and the Rosewill RHRC-11001 (RH-6) remote controls.
It probably needs some clean up to remove test code, but it does seem to work for all three keys. I used the up and down keys along with the Mute key (I changed the code to reflect the US convention of Mute to silence or lower the volume. Most devices I've seen do this by 20dB so one can tell the sound is still on but it is low enough not to interfere with a telephone conversation, etc.
I changed the mute level to correspond to this as well.
I'll post the code again when I finish cleaning it up.
Old 26th April 2012, 04:41 PM   #346
TheGimp's Avatar
Code now works with the following changes:
- Changed display to 16 X 4
- Removed Apple remote code
- added Sherriff's code for multiple remotes
- added decode for RC6
- added decode for SONY (not sure which one as there are many)
- added placeholder for Apple
- Reorganized code to put all IR Remote operations under one case statement
- Duplicated Button code for filter switch and added to case statement for remote filter operaton
- changed dim to mute and add mute value to volume value during mute (ie. mute by 30dB) so it mutes by a specified amount instead of an absolute amount.
- added Beta to code revision. now B 00.01.06
I'd still like to allow SW clip limit, and may get to it later.
I've attached Sherriff's IR code as well as my code.
Old 3rd May 2012, 09:12 PM   #347
TheGimp's Avatar
Does anyone have the SPDIF input working?
I've tried both my soundcard output and the output from a CDRom drive that I transformer coupled with resistors in an impedance matching network and neither work with this card.
I tried both sources with another DAC board I have (CM102S/CS8416/CS4398) and both worked with it so I don't think it is my source that is the issue.
Old 5th May 2012, 07:51 PM   #348
TheGimp's Avatar
I took the WM8804 receiver off ribbon cables, attached sockets on the bottom and plugged it directly on the pins on the DAC board. SPDIF still refuses to work.
Old 7th May 2012, 01:20 PM   #349
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
I've got a set of boards, but don't have the patients or time to mount these smd parts on it.
Anyone want the boards? or put it together for me?
Old 4th December 2012, 06:05 AM   #350
noSmoking is offline noSmoking  United States
noSmoking's Avatar
Hi Guys,
Has this thread died or morphed into another thread ,INFO PLEASE,
I would like to interface the filters and use the volume control in wm8741 ,anyone?
NS
High Performance WM8741 Upsampling DAC New Version build thread (show 'n tell too)Hide this!Advertise here!
High Performance WM8741 Upsampling DAC New Version - Group buy heartwinter Group Buys 114 13th April 2012 03:56 PM
High Performance WM8741 Super Mini DAC with I2S Data Switching PCB - Group Buy heartwinter Group Buys 26 19th January 2012 12:12 PM
High Performance WM8741 Super Mini DAC PCB Group buy heartwinter Group Buys 18 30th August 2011 05:45 PM
Wolfson High Performance 117dB DAC m.parigi Digital Source 1 21st February 2002 07:51 PM
Copyright ©1999-2017 diyAudio
