Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 30th January 2012, 05:13 AM   #51
Originally Posted by pinnocchio View Post
Yet another update!
Based on calcs done by randytsuch, I've got the closest match available for 0805 ceram caps.
Both caps on Wolfson receiver and MiniDac have changed to accomodate this.
On MiniDAC, removed 33pF and changed to 27pF
On receiver, removed 22pF and changed to 27pF
Both Crystals are 12Mhz 10PPM 18pF
@randytsuch, do you have a Mouser BOM to share?
Ciao!
Do
Last post of the night .
I have been working on a Mouser BOM.
I got to the through hole caps, and measured the lead pitch on them.
There are 4 sizes, 2, 2.5, 3.5 and 5 mm lead pitch. Not sure if you knew this when you picked your caps?
For example,
C56 is 2mm
C16 is 2.5mm
C7 is 3.5mm
C60 is 5mm
Randy
My system is here
http://randytsuch-audio.blogspot.com/2005/10/my-system.html
Old 30th January 2012, 05:25 AM   #52
pinnocchio's Avatar
Send a message via MSN to pinnocchio
For example,
C56 is 2mm
C16 is 2.5mm
C7 is 3.5mm
C60 is 5mm
Randy
The MKPs I made a conversion using the picture, so yes I have taken this into account. For as long as my conversions were right...
The smd components are 0805 which is standard, so it should be good. Kept all resistors at 0.1% tolerance for good matching.
I will probably skip the I2S logic but wouldn't mind keeping the spdif for connecting to older cd players. USB is a must!
Keep us informed and please PM me your BOM or simply post it when you're done.
I'm thinking doing it the same as yours.
Ciao!
Do
Old 30th January 2012, 10:27 AM   #53
Finished my BOM, not going to share, as it contains a list of elements available from local "non-line" shops. Went for 1% resistors (close examination of schematics does not reveal critical parts where close matching is a must), replaced some ELNAs to Sanyo, Sanyo for Rubycon, etc. depending on availabality. On this stage I cannot decide either to skip the whole headphone amp part or to change the volume pot to stereo, without switch, and leave the power supply for headphone amp always ON. The only source for ALPS listed in original BOM is Mouser, and the shipping for one pot to LV is 40 EUR
Old 30th January 2012, 11:50 AM   #54
pinnocchio's Avatar
Hi tornislv,
As posted under my bom, here's three places where you can get it
1 ALPS RK0971221Z05 Tangent’s Parts Shop $2.75 $2.75
AMB audio shop $3.25 $3.25 under "Panel components"
RK0971221Z05 ALPS Potentiometers $3.06 $3.06
Ciao!
Do
Old 30th January 2012, 01:29 PM   #55
Pinnochio,
all these merchants are in America, and the shipping to Europe for single part is way too expensive, I am used to use ELFA or Farnell with free shipping. :-)
Anyway thanks for help. :-)
Br,
Uldis
Old 5th February 2012, 05:59 AM   #56
pinnocchio's Avatar
Default Selling my boards
Guys and Gals,
I'm selling my boards... Unfortunately, I have to back off a little... I have 6 other projects queued up and this is just going to add to the pile. I need to be able to finish those projects and put them in nice boxes, not just keep them on a piece of plywood!
If anyone is interested, I have the main board, and the wolfson receiver with the mini logic converter.
I'll let everything go for 30$ US plus shipping...
I have not received the boards yet but will let you know when I do...
Any takers? Just PM me
Ciao!
Do
PREAMPs : α10 with JC-80 clone | B1 Buffer | X-10 | AMPs: β24 | Aleph 5 | ChipAmp LM3886-4780 | Hiraga | ML-2 | Fetzilla
DACs : TPA Buffalo II in Dual Mono + TP Legato 3.1 I/V | Tube-I-Zator I/V | TPA OPUS + IVY III Speakers : Jim Holtz Statements | KEF Q55
Old 9th February 2012, 03:57 PM   #57
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Default handy surface mounting technique
How to Solder SMD ICs the easy way!
Old 9th February 2012, 05:54 PM   #58
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Is there a documentation package available on the boards?
I ordered a set last week but don't expect them for a little while yet.
Old 9th February 2012, 07:14 PM   #59
Does anyone have a completed BOM? (from mouser or digikey)
Old 9th February 2012, 07:24 PM   #60
I'm getting kind of close to finishing a mouser bom, been delayed because of work and some other issues. I am currently only really worried about the main board, and I only plan to build the level converter daughterboard right now. You need this to connect a 5V arduino board to this DAC.
I'll post what I have pretty soon, there's a few caps I need to find. It will probably be missing some headers/connnectors/jacks, which I may not use.
Randy
My system is here
High Performance WM8741 Upsampling DAC New Version - Group buy heartwinter Group Buys 114 13th April 2012 03:56 PM
High Performance WM8741 Super Mini DAC with I2S Data Switching – PCB - Group Buy heartwinter Group Buys 26 19th January 2012 12:12 PM
High Performance WM8741 Super Mini DAC PCB Group buy heartwinter Group Buys 18 30th August 2011 05:45 PM
Wolfson High Performance 117dB DAC m.parigi Digital Source 1 21st February 2002 07:51 PM
Page generated in 0.12402 seconds (88.11% PHP - 11.89% MySQL) with 11 queries
