Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 19th April 2012, 12:49 AM   #331
TheGimp is offline TheGimp  United States
TheGimp's Avatar
I tried a second display and got the same results, so I don't think it is the display.
I'll start going through the code to see if I can convert it to support the Sony and RC6 remotes.
I tried modifying the SPDIF input without success. It goes o the bottom of the list.
Old 19th April 2012, 12:58 AM   #332
Since you are getting stuff on the display that you would expect, I think the display and the display IF must be fine. If there was a problem there, you would get garbage.
There is code to support "large characters". I think it uses a lookup table that is supposed to be included. Maybe the large character code is causing those funny charaters?
You could try to comment it out, and see what happens.
Randy
My system is here
http://randytsuch-audio.blogspot.com/2005/10/my-system.html
Old 19th April 2012, 01:54 AM   #333
TheGimp's Avatar
Good Idea, although I was thinking they were possibly bar code information for the volume.
Hopefully I can comment out the large character calls.
It is definitely the large character codes. I can see which ones are which and they all map to the set.
I guess the issue is that I really don't know what should be on the display.
There is a hint on the HiFiduino page.
Old 19th April 2012, 07:29 AM   #334
Turbon is offline Turbon  Sweden
Turbon's Avatar
Have a look on my latest image I uploaded a page or two back - theres what you should expect on the LCD. As I see it you got everything but in the wrong places.
Have a look at these and experiment:
lcd.setCursor(col,row);
The code original code made me totally confused as parts seemed to be lcd.setCursor(row,col); which didn't fit my LCD.
Brgds
These are my principles, and if you don't like them... well, I have others.
Old 19th April 2012, 01:23 PM   #335
TheGimp's Avatar
Thanks Trubon. I'm wondering if my LCD displays might be the problem. T
hey are populated with original HD44780A00 parts.
The only date coded part I can read looks like it has a date codes of 1976.
the "A00" makes me think they are early release parts. There could have been a change in design that effected the mapping of the display which would account for it's behavior.
Then again, the current displays could be different from the original even though they claim compatibility, and the code is written for the new displays.
I need to find datasheets on both display ICs. If I can understand the difference ti should not be difficult to fix the code to work with my displays.
That or order a new one.
Old 19th April 2012, 02:20 PM   #336
TheGimp's Avatar
Ha..ha..ha....
4 X 16 display not 4 X 20
The manual does not show a 4 X 16 display, and it is the same width as the new 2 X 40 displays I have so I thought it was 4 X 20. Not!
Sparkfun was faster even though it was almost twice as much.
Old 20th April 2012, 12:20 AM   #337
TheGimp's Avatar
There appear to be some changes between the HD44780A00 and the HD44780U versions.
I had to index at 0,0 and 1,0 for rows 1 and 2, and index at -4,2 and -4,3 for rows 3 and 4 to get the display to align.
Then I had to add -4 and -8 off sets to the two row indices.
Looks like it will run with the 16X4 display although it is a bit tight.
All this will be tossed when a proper 20X4 display arrives, but I can play with it now and I'm learning the code so all is not in vain.
Old 20th April 2012, 03:20 PM   #338
TheGimp's Avatar
I've removed the apple IR code, and integrated Ken Shirriff's IRrecv program into the main code and got it to compile w/o errors.
I'll start debugging it this weekend.
Old 20th April 2012, 05:06 PM   #339
Turbon's Avatar
Good to hear that you are making progress TheGimp!
Brgds
Old 21st April 2012, 01:40 AM   #340
TheGimp's Avatar
TKS Turbon.
I patched the code in to switch the remote but it does not work.
So I loaded the demo. It does not work (probably something I did wrong in changing from the serial output to the LCD).
I'll probably beat on it a while.
High Performance WM8741 Upsampling DAC New Version - Group buy heartwinter Group Buys 114 13th April 2012 03:56 PM
High Performance WM8741 Super Mini DAC with I2S Data Switching – PCB - Group Buy heartwinter Group Buys 26 19th January 2012 12:12 PM
High Performance WM8741 Super Mini DAC PCB Group buy heartwinter Group Buys 18 30th August 2011 05:45 PM
Wolfson High Performance 117dB DAC m.parigi Digital Source 1 21st February 2002 07:51 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
