Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Sick Proton ac-620 needs your help
Old 13th January 2012, 10:50 AM   #1
S.Spielbergo is offline S.Spielbergo  United States
Default Sick Proton ac-620 needs your help
About a year ago my beloved Proton ac-620 cd player (great Dieter Rams knock off) went on the fritz, any disc inserted would just spin wildly (violently) out of control without being read. I have already rebuilt most of the pc board's analog and some of the digital section with only a bad resistor needing repair in the servo section. Its a great Philips based player from 1990 with the TDA1541 and cdm-4 mechanism so I hate to see it sitting there all slumped over on the "dead electronics" shelf. I have since tried a handfull of more modern players but have been unimpressed, build quality on modern equipment is unbelieveably chintzy. Any help is greatly apreciated guys.
Old 13th January 2012, 04:29 PM   #2
stephensank is offline stephensank  United States
The first thing to do on any Philips based unit like these is to replace every non-Nichicon electrolytic cap in the unit, especially in servo, supply & syscon areas. Have you done this yet?
Old 14th January 2012, 06:07 AM   #3
I replaced all electrolytic caps during the rebuild a couple years ago.
Old 14th January 2012, 04:01 PM   #4
Well, having encountered this symptom only a few times, more than a few years ago, I can't recall the solution. However, the next steps I would take would be to 1)check laser current & focus offset adjustments, 2)assuming it's a philips or same style pcb, check for excess current draw on servo, drive & dsp chips via voltage drop accross the low value resistor feeding supply to each chip/group, 3)resolder all of these chips & anything else not 100% positively perfect looking, 4)unplug, replug & wiggle all connectors. After that, time to get out an oscilloscope.
Sick Proton ac-620 needs your helpHide this!Advertise here!
sick amp please help richa Chip Amps 21 6th September 2012 08:47 PM
Got this on this on ebay..sick amp benny_rx_blanco Car Audio 2 8th April 2009 10:18 PM
New sick amplifier Solosound Car Audio 3 5th December 2008 01:29 AM
My Fender 6G15 is sick bassman314 Instruments and Amps 8 29th January 2007 02:54 PM
Help - Z4 sick on startup BeaufortRalph Pass Labs 5 18th April 2005 06:50 PM
