Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
DIR9001 vs CS8416 and poss CS8412
Old 12th January 2012, 02:12 AM   #11
SoNic_real_one is offline SoNic_real_one  United States
@abraxalito - you are one of the few that understand what that xtall clock does in WM8805.
The usual "mantra" that I saw around here is that somehow "reclocks" the incoming SPDIF signal.
Old 12th January 2012, 02:26 AM   #12
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Perhaps those naive punters think that because there's an XTAL there's a varactor inside the WM8805 and that makes for a lower jitter (from narrower bandwidth) PLL? From reading the datasheet though it looks as though the WM8805's key feature is that the PLL is digital rather than analog.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 12th January 2012, 10:07 AM   #13
UV101 is offline UV101  England
UV101's Avatar
I wonder if the best way forward would be to use the WM in hardware mode with on a board thats capable of CPU integration later?
What realistically could be used to control the chip? PIC? I guess you are just writing word value to specific memory in order to set modes etc?
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 12th January 2012, 10:12 AM   #14
abraxalito's Avatar
ThorstenL's actually worked with programming the part so I defer to his greater experience.
As regards CPUs, I'm a devotee of ARM so I'm planning to use LPC1313 or LPC1113 in my design. That's because these have the grunt to do a bit of DSP (oversampling filter for example) and are barely more expensive than a PIC (sub $2). They have hardware I2C so at least part of the interfacing is done already.
Old 13th January 2012, 12:19 AM   #15
Realistically a PIC10 would be easier to implement and costs less than 1 USD. But... is it worth dealing with the added circuits and RF noise? Do you have the programmer for it? You won't gain performance - 192kHz sample rate does not perform better in modern DAC's - look at their data sheets. Cannot "travel" via most of optical converters either.
Old 13th January 2012, 01:56 AM   #16
abraxalito's Avatar
It doesn't appear to have the requisite serial ports for I2S. So as a way of programming the 8805 its fine, but doesn't add much interesting by way of DAC features. Like volume control to offer just one possibility.
All reward is dependent on risk. Why would there be more 'added circuits' than with your PIC10 idea? Or are you comparing CPU with no CPU at all?
For sure, that's one reason I chose this rather than a family I don't have the kit for. It programs itself though, just needs an interface.
You're jumping to delusions - I wasn't planning 192kHz nor was I planning to use a 'modern DAC' in my design. But I agree with your point - taking the PCM1704 as an example, the THD goes up as the sample rate goes up.
Old 13th January 2012, 10:06 AM   #17
UV101's Avatar
I do have a pic programmer and limited experience of programming with it!! (Never used it in ager as I intended!)
I'd not really be interested in the advanced features of the receiver other than the input selector might be useful? I cant help but think external mechanical control would possibly be better?
All this considered, it still sounds like the advanced clocking of the WM8805 even in H/W mode may be prefereable to the DIR9001?
Old 13th January 2012, 12:01 PM   #18
WM8805 does NOT have any "advanced clocking", I was sure that you will missunderstand that - see my discution above.
It locks on to the SPDIF signal with the PLL loop, exactly like any other receiver. With 50pS jitter - like DIR9001.
PS: My bad, PIC10 was just an ideea of cheap, simple (6 pin) way to program the ports. Sorry, for i2c lines, there is PIC12F1822 at 1.15$ and 8 pin.
Old 13th January 2012, 01:34 PM   #19
UV101's Avatar
Ok my misunderstanding. Nothing to be had by using the WM8805 in hardware mode over the DIR. The DIR it is then
DIR9001 vs CS8416 and poss CS8412Hide this!Advertise here!
A little advice if poss.....? mashypie Full Range 2 14th November 2010 07:13 PM
FS: DIR9001 to CS8412 converter board spencer Swap Meet 101 24th August 2010 10:16 AM
DIR9001 to CS8412 for sale... sklimek Swap Meet 1 6th April 2009 12:17 AM
DIR9001 Vs CS8416 bou Digital Source 1 13th June 2007 01:26 PM
CS8412 or CS8416 pigoia Digital Source 4 12th April 2007 10:03 PM
