TDA1543 Non OS DAC - Page 6 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 27th September 2003, 05:51 PM   #51
wmincy is offline wmincy  Malaysia
Default help with TDA1543A
hello everyone,
does anyone have a remedy for the TDA1543A to make it functions in NON-OS DAC??
Pleaseee helppppp
the fever of DIY HI-FI will NEVER be cured !!!!
Old 28th September 2003, 08:28 AM   #52
diyAudio Moderator Emeritus
jean-paul's Avatar
Buy a TDA1543 for 2 $ and save a lot of time thinking how to do it with TDA1543A.
It's only audio. Member of the non modular PCB design committee
Old 28th September 2003, 08:48 AM   #53
Banned
Send a message via Yahoo to Elso Kwak
Default Re: help with TDA1543A
Originally posted by wmincy
hello everyone,
Pleaseee helppppp
Hi wmincy,
The TDA1543A does not work with CS8412 or CS8414.
http://db.audioasylum.com/cgi/m.pl?f...3a&r=&session=
Follow Jean-Pauls advice and get a TDA1543 without the A.
Old 28th September 2003, 02:48 PM   #54
Default TDA1543A in OB format
Thanks Jean-Paul and Elso,
As Elso said that the TDA1543A supports only OB format (offset-binary) I found this on a web page:
Offset-binary encoding represents the range of amplitude values as an unsigned number, with the midpoint of the range representing silence. For example, an 8-bit sample stored in offset-binary format would contain sample values ranging from 0 to 255, with a value of 128 specifying silence (no amplitude). Samples in Macintosh sound resources are stored in offset-binary form.
Twos-complement encoding stores the amplitude values as a signed number--in this case silence is represented by a sample value of 0. Using the same 8-bit example, twos-complement values would range from -128 to 127, with 0 meaning silence.
Mincy
Old 29th September 2003, 03:15 PM   #55
guido is offline guido  Netherlands
guido's Avatar
Don't mix up the encoding of the data with the way the three lines are interacting. E.g. I2S could have the 16 bit encoded either way (it's not in reallity but..).
The format is more about the relation of the clock and datalines, not the encoding.
GuidoB
GuidoB
Old 1st October 2003, 11:36 AM   #56
Previously: Kuei Yang Wang
Konnichiwa,
Akwaba from Accra.
Just dropping in while my pretty bride is off on other business....
Originally posted by jean-paul
I'll do the TDA1545A SMD support for the PCB if you can supply me a nice and simple output stage design ( if possible ).
The 1545 and 1543 have pretty much the same pinout, both can if you MUST be used passive I/V, the key difference is that the 1543 has a reference resistor to ground while the 1545 has a RCR filter *11k/4u7/11k to +V from the ref pin. All else can be similar to the same, except the TDA1545 is limited to 5V supplies and thus will not give much level with passive I/V.
I have designed previously an active, valve I/V converter and 3rd order LPF using Valves for the 1545, it should float around somewhere on the net (probably in my group - whoever digs it up feel free to repost info here). I would suggest that any active I/V should be off board as there are so many options, from Op-Amp over valves or passive with a low gain amplifier stage etc....
It will be supporting TDA1543 DIL and TDA1545A SMD then.
Then it will also support TDA1545 DIL and TDA1543 SMD....
Let me think again about the reclocking. Did a design on that but lost the file when it was completed. It used the Tent module.
I think it's worthwhile. AFTER my experiences feding the Ack!Dack a Datastream 'upsampled' via CS8420 (before heading off to get married) I'd be tempted to suggest a second PCB with CS8420 support!
Sayonara
Old 1st October 2003, 04:53 PM   #57
jam is offline jam  United States
jam's Avatar
Jean-Paul,
You mention an early version of (your) dac. It looks a lot like Scott Nixon's dac layout to me. What gives?
Jam
Old 1st October 2003, 06:23 PM   #58
jean-paul's Avatar
With 20 components they all look like each other more or less BTW it is not my DAC but my version of the DAC.
Since it was an open source project on the Chips Amp board you'll see several variants all resembling eachother. Richard Murdey designed a version as well that was rather unique but it was never produced.
Scott made the first version for the Chip Amp board and I ordered one. After not having heard a reply after 3 weeks I decided to roll my own after careful looking at the pics that were shown at the Chip Amp board. The design was publicly discussed and adapted.
When Scott reacted I had finished my first version which indeed has very strong influences from Scott's A version certainly concerning ground routing. I remember discussing the board I layed out, the modes of CS8412 and I/V + Iref-resistors per mail with Scott. We did not agree on the 8/9 V supply after bad results I decided for 5 V and later 6 V that Fedde advised me. The later versions don't have the similarities as the version on the pics. I was so eager after the results I read that I made it myself. Scott still not offers a version with a transformer, discrete supply for the TDA and Super E so I'll jump in that gap so to speak. With these features resemblance is shrinking. If he would offer such a board I'd probably buy it.
Scott is a nice guy but the schematic isn't his or anyones since it was an open source project, this is confirmed by Richard Murdey who was one of the ones that started the project. There is no IP or copyright involved of any kind. Everyone can make one and is free to do so. This does NOT apply to his tube buffer etc. of course.
The new design and schematic will be publicly published here so please wait for that.
Old 1st October 2003, 06:34 PM   #59
Coulomb is offline Coulomb  England
Coulomb's Avatar
That's nice, but something is either unique or not, no amount of modifiers can alter that fact. :-)
Anthony
Old 1st October 2003, 06:40 PM   #60
jean-paul's Avatar
In fact it was never built but it was only drawn AFAIK. The uniqueness of this DAC isn't there since it was an open source project that everyone could follow. Richards layout looked nice but it had some drawbacks. Goal of the design was short signal paths and optimal ground routing. Scotts design was the first to be really OK.
Practically all non os DAC's with CS8412 and TDA1543 are variations on the same theme. Clearly it started off as trying to copy the 47Labs DAC ( I missed that stage ). Same as with the Gaincard/clone thing...
Tda1543 fili Digital Source 6 7th July 2014 04:04 PM
Wtb: Tda1543 leadbelly Swap Meet 0 19th October 2006 05:42 AM
USB-I2S-TDA1543 kit jkeny Digital Source 0 4th April 2006 10:56 AM
TDA1543 dac dariusku Digital Source 3 31st March 2006 06:38 PM
Where to buy TDA1543 D/A stan_33 Digital Source 32 7th May 2004 07:54 AM
Copyright 1999-2017 diyAudio
