CD63 display died, please help - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 2nd March 2005, 08:17 AM   #21
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Ruach,
I am delighted to have receive your response. If I have time tonight I will go inside and look for damage around C815. That part location sounds familiar, so it's probably one I changed
Old 2nd March 2005, 09:04 AM   #22
karma is offline karma  Canada
karma's Avatar
like any tube it has a getter in the corner to remove any extra air
when it was first made. it should be silver if it white or brown
it likely has an air leak. and would need to be replaced.
there should be a little glass tube sticking out the side where
thay removed the air. see if it has been snaped off by mistake
if so its toast
the plastic cover is under this glass tube somtimes removing it
snaps it off
looks white to me
Old 2nd March 2005, 09:36 AM   #23
SimontY's Avatar
if so its toast
snaps it off
looks white to me
Hi karma,
From memory at least, the discoloured corner is not where the small glass tube is. I think it's located on the other side. I will look when I can (I'm at work now).
Old 2nd March 2005, 12:40 PM   #24
Ruach is offline Ruach  Singapore
Glad to help.
I had hell for the whole day and night when the display "died".
The copper threads connected to C815 (if I remembered correctly) are very thin and can be lifted quite easily.
C815 is next to the 5V voltage regulator with the heatsink.
Best of luck.
If you managed to have your CD63 up and running again, I would recommend an additional transformer for your CD63, which is guaranteed to do wonders.
Old 2nd March 2005, 02:49 PM   #25
SimontY's Avatar
Thanks!
My CD63 has been in constant use all this time, only with no display... I just don't know what track is playing all time
When you say "additional transformer" do you mean to suggest separating the PSU sections out with dedicated transformers for the different sections, or an isolation transformer? I am using an isolation transformer just for the player, which does a lot of good. I have a dedicated external PSU to run the clock, but everything else is normal psu-wise, other than the usual schottky diodes, changed caps etc.
Old 2nd March 2005, 04:56 PM   #26
I meant separating the PSU for the DAC (supplying voltage to the 7805 voltage regulator) with a dedicated transformer. A 30VA toroidal would suffice.
Old 2nd March 2005, 07:52 PM   #27
SimontY's Avatar
Ahha, very interesting. Will have to look into this possibility... I've done a lot of work on it, so I might as well do everything sensible!
Old 2nd March 2005, 08:18 PM   #28
check this out:
http://db.audioasylum.com/cgi/m.mpl?...er&r=&session=
Old 2nd March 2005, 10:14 PM   #29
Simon - would you like a free, known-good display unit as a backup/spare? Drop me an email and I'll post you the front panel off my old CD63.
Old 2nd March 2005, 11:13 PM   #30
SimontY's Avatar
check this out:
Ooh, very interesting! Just need to figure out what I can fit in and where, and which wires to snip and points to solder to
First tho, I am trying different op-amps. I'm sick of the OPA2604 I put in, and am trialling 2132....
Marantz cd63 ki no display paul_peraic Digital Source 2 25th May 2008 05:22 PM
M DCX died, what to do? sqlkev Digital Line Level 3 22nd May 2006 07:03 PM
CD63 display problem Chivvyp Digital Source 15 8th May 2006 06:35 PM
My philips cd723 display died too chris chiang Digital Source 1 16th September 2003 12:41 PM
Copyright 1999-2017 diyAudio
