CD63 display died, please help - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 15th September 2003, 09:27 PM   #11
diyAudio Moderator Emeritus
jean-paul's Avatar
I just don't know much more than the VERY basics - but I would know nothing if it wasn't for the desire to achieve real music from my system...and DIY audio
You have a point there and to be honest I started the same way too. Then I learnt the basics and errors became less and I actually started to understand what I was doing.
Continue with the mods but work tidy and thoruoghly think over what you want to do before doing it. This forum can be of great help when you're not sure what to do.
Please measure the display tubes voltage as I guess it doesn't function as it should.
It's only audio. Member of the non modular PCB design committee
Old 15th September 2003, 09:29 PM   #12
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
That's encouraging :-)
-Simon
Old 15th September 2003, 09:35 PM   #13
jean-paul's Avatar
And I burnt some cdplayers too
You can find the service manual here:
http://www.alw.audio.dsl.pipex.com/D...ice_Manual.pdf
Check the voltage at Q581's output ( -24.4 V ) and between VF1 and VF2 ( 3.6 V ). Be careful not to short pins when you measure.
VF1 and VF2 have -19.5 V with repect to ground. If voltages are OK there is probably one of the transistors blown that switch on the display voltage like Q852 etc.
Mmm, my 1000st post ! Time for a
Old 15th September 2003, 09:37 PM   #14
SimontY's Avatar
Thanks for getting the link, but I got that (from a thread on here) already!
I was looking at it only 30 minutes ago
-Simon
Old 15th September 2003, 09:44 PM   #15
SimontY's Avatar
Just in case you're interested, here is a pic from yesterday, just before the display fault occured.
You can see the CAT5 lead, input cap, rearranged Elna caps, Audiocom DVC-1 clock and power input with black gate, changed output caps, ic shielding with blu-tac etc etc. Its so much fun, isn't it? (apart from when it goes wrong...)
Congratulations on your 1000th post!!!
I will hopefully check the thing tomorrow, I'm too tired now
Old 15th September 2003, 10:05 PM   #16
Default moot point
Hi
In the process of fixing this problem, you may want to add a switch to manually turn off the display My Denon DCD-1560 cd player has a front panel button to do just that. Apparently turning off all the display LED's leads to a quieter playback circuit (since all the switching diodes are now off). I have seen a few other older high-end cd players that have the same facility.
Good luck with the solder iron!
Cheers -
Pradeep
Old 15th September 2003, 10:07 PM   #17
jean-paul's Avatar
CD63 doesn't have a multiplexing ( and terribly interfering ) LED display, it has a display tube.
Please study the schematic if nothing can blow while switching the display off and on. Better repair it first before adding a switch to switch it off again
IME there is a small difference when the display isn't lit but it can be darn impractical now and then
Old 1st March 2005, 07:48 PM   #18
SimontY's Avatar
So, 1.5 years has gone and I feel like trying to fix my cd player display again, lol
Today I actually removed the display/control board from it's plastic surroundings (the player's fascia). The display tube has a sort of stained, dark area in one corner - could it be burnt/broken?
I plucked up the courage to measure the voltage going in to the display/control umbelical socket - this was 5v as it's meant to be, so I've narrowed the problem down now.
Perhaps a photo of the display will help, I'll go and take one...
Old 1st March 2005, 08:19 PM   #19
SimontY's Avatar
Righto, can anyone who knows what these are meant to look like please tell me if it's supposed to have that cr@p in the corner?
Old 2nd March 2005, 06:19 AM   #20
Ruach is offline Ruach  Singapore
I may have the solution to your problem.
I had the same problem on my CD63 some years back when I was modding it.
In my situation, everything on the CD63 worked except the display.
After one day/nite of troubleshooting, I discovered that one of the copper threads supplying 5V to the microprocessor and data i/c has broken contact. A simple hardwiring fixed the problem.
You may have lifted the thread when you are installing a bigger capacitor at C815.
Hope this helps.
Marantz cd63 ki no display paul_peraic Digital Source 2 25th May 2008 05:22 PM
M DCX died, what to do? sqlkev Digital Line Level 3 22nd May 2006 07:03 PM
CD63 display problem Chivvyp Digital Source 15 8th May 2006 06:35 PM
My philips cd723 display died too chris chiang Digital Source 1 16th September 2003 12:41 PM
Copyright 1999-2017 diyAudio
