Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 25th December 2011, 01:08 AM   #11
JoeDJ is offline JoeDJ  United States
I got that FiiO E6 today. It really does not increase the volume that much..... hardly at all actually.
However, the E6 does seems quite usefull when using my MP3 player plugged into the AUX port of my car's less that stellar stock stereo. So, I will still have a use for it as I suspected.
I wonder, would an average 9v a CMoy amp have a higher output for use in my home sys?
Old 25th December 2011, 06:26 AM   #12
Mooly's Avatar
A full size CD player can output 2vrms. Thats around 5.5 volts pk/pk and so an opamp (or transistor) gain stage running from a single 9 volt supply should be plenty.
A simulation free zone. Design it, build it, test it.
Old 25th December 2011, 07:52 AM   #13
dangus is offline dangus  Canada
Does the Clip+ have the volume limiting "feature" activated? Supposedly, there's EU firmware that makes limiting mandatory. Google Sansa Clip+ volume limit
Old 25th December 2011, 02:52 PM   #14
Thanks for the input...
The Sansa Clip has plenty of volume (purchased in the US) with both headpones I currently have.....a cheap Koss used stictly for computers/outdoors and my much better Audia Technica phones for music. In fact with the Audio Technica phones, I can turn the volume down to about 2/3.
As I said, the voulume only became somewhat of a problem when fed through my home sys when I got the less efficient AS speakers and only with some songs.
This is why I want to get some sort of inexpensive "preamp" to boost the output a bit. Also, running the Sansa at full volume depletes the battery faster.
If no one has a better/different suggestion, after the new year, I wil try one of those inexpensive 9v CMoys amps on e-Bay..... the ones from the US dealer that use the TI opamp 2227 chip.
Micro Cmoy headphone amp - Opamp 2227 - Amplifier Tiger | eBay
He seems to use high quality components.
For me, it's not worth building my own as the price is relatively cheap for an assembled one.
Old 30th December 2011, 03:08 AM   #15
FWIW. .....I got a CMoy amp and it solved my problem.........volume is now more than adequate for the most part.
Old 30th December 2011, 06:45 AM   #16
Mooly's Avatar
Thanks for the update.
Converting car cd-player into an mp3 player... dionisis84 Car Audio 10 4th November 2006 09:00 PM
mp3 player with usb i2s output guglielmope Digital Source 1 3rd October 2006 07:07 PM
[project] 12v in laptop (5v) HDD .mp3 player. USB access, AUX output Sedodes Everything Else 0 21st December 2005 07:44 PM
MP3 Player mcl Everything Else 1 11th February 2005 07:51 PM
mp3 or wma hard drive mp3 player martin88 Digital Source 2 6th August 2004 09:50 AM
Page generated in 0.07459 seconds (83.91% PHP - 16.09% MySQL) with 10 queries
