Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 2nd February 2012, 09:20 PM   #311
Mayday is offline Mayday  Sweden
This build is now about $5 short of $300...
But why complain, I've gotten so much fun DIY-stuff for free recently
The more you learn, the more you realize how little you know...
Mayday DIY blogg
Old 8th February 2012, 09:02 AM   #312
Build is not abandoned, waiting for some parts and to afford to order other parts.
Also I've been busy with this tube amp
I found the fault, a resistor that was broken(a 51R resistor responsible for poweringen one channel of the amp). Also I'll put a second on-off switch (on B+) so that I can switch on heaters, and then 20-30sec later switch on B+.
A manual softstart of sorts.
Mayday DIY blogg
Old 8th February 2012, 01:19 PM   #313
Done Not pretty, but it works, I'll make it pretty later when I've tested it w tubes in place. Enough OT, sorry.
Mayday DIY blogg
Old 10th February 2012, 10:57 AM   #314
Got the CS8412 today.
Mayday DIY blogg
Old 15th February 2012, 09:01 AM   #315
Got the PS's needed for the ECC86 output today.
24Vdc/1A and 6Vdc/1A.
Mayday DIY blogg
Old 18th February 2012, 08:40 PM   #316
I've ordered a custom transformer for the DAC.
It's a toroid 60VA 230V primary.
Secondaries:
0-9Vac 1A
0-15Vac 1A
16-0-16Vac 1A
A picture of a friends transformer from the same company that's making mine.
This way I get away with using one transformer and it was actually the cheapest option.
This leaves room for a copper "wall" between transformer and DAC (and later tube output).
Mayday DIY blogg
Old 18th February 2012, 08:50 PM   #317
Could someone please give me the search words for ebay or link me to a place where I can get a dip socket with the right dimensions that can be modified to be a TCXO-socket(cut to size and remove excess pins I guess). I want this in part to be able to swap/upgrade TCXO and also to change them in time as they age.
Mayday DIY blogg
Old 18th February 2012, 09:40 PM   #318
With transformer the total so far comes to $387.
Still left to buy:
TCXO( price depends on which I chose) and a top for the enclosure (15usd)
Mayday DIY blogg
Old 19th February 2012, 10:06 AM   #319
I have 4pcs OPA604 and 2pcs NE5534.
I'm thinking of putting the entire thing together when I get the transformer and TCXO using OPA604 for I/V and Buffer/Filtering.
Listen to the dac this way for a while before putting in the ECC86 outputstage.
Will this do as a TCXO-socket? Either breaking of 4 pins or two rows and removing unused pins(this approach would make for a more stable socket).
Mayday DIY blogg
Old 21st February 2012, 12:51 AM   #320
The above and also 1ppm low jitter Valab TCXO ordered.
Mayday DIY blogg
HifiDIY TDA1541A DAC Kit Leaving it on at all time? manp111 Digital Line Level 1 6th June 2011 08:27 AM
Marantz CD95 -- 2 x TDA1541A-S1 + 2 x SAA7220P/B -- How Does It Work? poynton Digital Source 5 23rd March 2011 10:38 PM
FS: SAA7220P/A and SAA7220P/B Joris Swap Meet 3 20th May 2010 06:27 AM
FS: TDA1541A S2 and SAA7220P/B paulyang Swap Meet 9 19th January 2006 09:06 PM
Page generated in 0.10016 seconds (80.56% PHP - 19.44% MySQL) with 11 queries
