| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I'm currently using 2 digital sources, Marantz CD-60(undergoing mods) and a rather cheap USB-DAC w digital coax out.
I'm getting quite fond of the sound from the modded CD-60(TDA1541A/SAA7220P/B). At first I thought there might be a way to alter the CD-50(will be modded too) I also own so that it had a digital coax in, this might be a bit harder then it first seems I guess. SO, I'm looking for DAC's (preferably using TDA1541A or S1, S2) that will fit my taste and not too thick wallet. I have had a DAC-AH(modded, 1543 direct to RCA via PIO caps, not my work though) in the past connected to my PC via a Trends Audio UD10(I think it was called that). I think I prefer TDA1541(even though not fully modded yet) to TDA1543. OR any relatively cheap DAC's that can be modded to equal the sound of a modded CD-60 or better. Maybe my USB-DAC, called NIE, can be modded to sound a bit better and I can stick with it for now? |
#2 |
#3 |
If this topic is better suited under Digital line level, please feel free to move it
#4 |
No OpAmp (filters) after a 1543 in NOS mode? That thing probably sounds horrid...
#5 | |
I've had a Cayin CDT-17A in the past I was pleased with, I was also pleased with Trend Audio UD10 connected to a DAC-AH (TDA1543 in parallel, NOS, and TDA1543 to out via PIO caps). But for a while I had other intrests so those have all been sold. Since I have a CD-50 too, it would be perfect if it could be fitted w digital in and used as a DAC, but that's probably alot harder then it sounds. |
| Show my PCM1794 DAC TSOLINK + COAX + USB input, Line and headphone AMP output | AWaudio | Vendor's Bazaar | 3 | 2nd January 2012 12:44 PM |
| FS - $150 - Monica 2 DAC (USB + Coax) + SS I/V Gain Stage | ianp | Swap Meet | 0 | 15th August 2011 10:18 PM |
| Squeezebox > DAC vs PC > DAC Audio Quality? | erin | Digital Source | 32 | 27th July 2011 10:16 AM |
| Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A | novec | Digital Line Level | 11 | 11th May 2010 11:57 AM |
| Direct Wiring a DDDAC USB-->I2S to a P3A DAC I2S DIN input | dkj7a | Digital Source | 1 | 26th March 2006 05:46 PM |
| Page generated in 0.08110 seconds (78.65% PHP - 21.35% MySQL) with 10 queries |
