| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hello,
I have a PCM1704K based dac and the PCB was whatever I found at the time. It has many ground plane areas on the 2 layers, some floating (not connected) some grounded. Images attached, purple shows the ground planes and highlights show the area where they are connected. I have read numerous articles on grounding and I'm leaning towards a single ground plane. Article However I'm wondering wheter to leave the planes as is or to cut some traces and connect them differently. The two options are star-ground or jumpers to simulate one single ground plane. If i go for jumpers - then obvioussly they would be at the edges of the current areas. If i go for star shoud I connect to the center of the areas instead ? What should I do for the smaller areas that are 'floating' ie: not connected? Thanks. |
#2 |
Star grounds are no good for digital.
I would cut down on the width of your signal tracks firstly, they do not need to be that wide, that will allow for better copper pour of the ground. Secondly stich the top and bottom grounds together using numerous stiching vias to create as near as possible a contigous plane. Unconnected area of copper is a no no. Dont realy require curved tracks, benefits will be minimal at these frequencies if any. Design would benefit from moving the components much nrearer together. Why so many largish electroylitics? |
#3 |
Thanks,
I'll get to it asap. The reason for the electrolytics near the edges is that those a power regulators. There are 6 separate rectifiers+regulators. Just to be clear you mean I SHOULD connect the floating areas to ground, right? Except maybe when too small. Agree the design is too far appart but not much I can do about that...on this project. |
#4 |
Yes, any unconnected copper is bad practice, tie the ground areas together with as many vias as possible without going crazy. If you cant connect small areas try and delete them.
#5 |
+1 Remember that at RF frequencies EVERTHING is an antenna/waveguide/resonator, all due to simple physical geometry and its relationships with the wavelengths involved.
All generalizations are false, including this one. |
#6 |
better to have areas of ground tied together with multiple vais, better for signal integrity, provides lower impedance return and allows return current to follow more closely the path of least inductance, which will be the path under the trace. Also having multiple vias will reduce the area or size of a feature electronicly in relation to wavelength, increasing the frequencies that may cause you problems, for this reason use at least two vias per area at opposite ends to avoid creating a diplole structure.
If you PCB manufacturer can handle it some 0.3mm vias would be nice, but for costs you may have to use 0.5mm finished hole vias. |
#7 |
I have separate power supplies (6 or so) and associated regulator circuites on the same board.
Should I have 6 ground planes, one for each 'area' supplied or one unified ground plane? (Nevermind digital/analog). Thanks. |
#8 |
One contigous ground.
| Ground Plane Prototyping | keantoken | Solid State | 9 | 22nd June 2011 07:07 AM |
| Ground plane or star ground? | yakideo | Chip Amps | 6 | 27th March 2011 05:06 PM |
| Ground Plane vs Star earth | duderduderini | Tubes / Valves | 80 | 17th September 2010 10:30 PM |
| star ground vs. ground plane | Sebastiaan | Chip Amps | 15 | 10th May 2009 05:05 PM |
| Using Ground Plane on Both sides of Board? | ppl | Solid State | 11 | 13th October 2006 04:14 PM |
| Page generated in 0.10126 seconds (74.32% PHP - 25.68% MySQL) with 11 queries |
