Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th December 2011, 08:38 PM   #1
georgehifi's Avatar
Send a message via MSN to georgehifi
Default A different way of powering I/V opamps
I would like some I/V guru's input to this way of powering an I/V opamp or output buffer, as it has been getting some good feedback from those who have implemented it.
Post 16 says it's a Gyrator circuit and would definately be better/sound better because of the improved PSRR figures.
Powering Opamps???
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 7th December 2011, 10:04 PM   #2
The feedback of his e bay customers says it all - not one complaint.
Assuming of course they all tried it before they left the feedback in the first place.
Interesting indeed.
Oh and.. hello George - it's been a while
Hope all is well
Old 7th December 2011, 11:00 PM   #3
No. The posts criticising this usage are correct - those two transistors ONLY add a diode voltage drop in series with each rail. No benefit in that alone, at all.
Old 7th December 2011, 11:19 PM   #4
Edit to add: the only way this could help is if the intrinsic impedance of this diode juntion made a useful filter with the decoupling caps at the opamp supply pins.
For something like AD825, with 5mA/rail supply current that means an effective added supply impedance of about 5-6ohms (=26mV/I,mA - the same as any emitter-follower output Z) and so assuming say 0.1uf bypass caps at the opaamp, a supply filter point above 100Khz; maybe significantly lower with larger local decoupling caps.
In other words simply adding say 5ohms in series in each supply line will provide at least the same effect, very cheaply. And without the BS.
Old 7th December 2011, 11:39 PM   #5
BS Martin ?
Not here... surely ?
Old 8th December 2011, 01:31 AM   #6
Joachim Gerhard's Avatar
I simply think it is drawn wrong. With a capacitor in the base to ground it is a capacitance multiplier. You could argue that this is a kind of Gyrator then but there are better circuits that simulate a coil.
Old 8th December 2011, 02:02 AM   #7
I have now seen the website where this is promoted. When it works, fine. I would add the cap for sure.
Old 8th December 2011, 08:17 AM   #8
qusp is offline qusp  Australia
Sometimes a square peg fits a round hole just fine
qusp's Avatar
hmm, well considering the usually quite massive PSRR of modern opamps, is this really something to bother with? or is it simply a way to avoid proper regulation and local decoupling for each chip? wouldnt it be perhaps more useful to add ferrite beads, or the newish NFM C-L-C filter network types to address the problem at higher frequency, but still leave the DC low impedance?
Old 8th December 2011, 10:31 AM   #9
It is frequent on ebay not to show the complete schematics, to prevent "stealing" ideeas Even if they are 20 years old.
Powering Opamps??? georgehifi Solid State 269 23rd January 2012 10:44 PM
AF filter using opamps - substitution of opamps neazoi Solid State 19 5th October 2011 04:01 PM
Powering multiple opamps - cascaded rails or starred? mikesnowdon Power Supplies 2 11th April 2010 12:36 AM
FS: Power Chip OpAmps and other OpAmps & D to A Converter dtm1962 Swap Meet 4 12th January 2006 10:07 PM
How long will 9V batteries last for powering opamps? PaulHilgeman Parts 4 28th February 2003 04:05 PM
Page generated in 0.10057 seconds (76.88% PHP - 23.12% MySQL) with 11 queries
