| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I designed a simple mixer with a mcp4231. It sounded ok on the breadboard.
I carefully followed the datasheet in designing the circuit. It worked so I got a 6 channel pcb made. I noticed it when testing that even though the pot was set to zero a small amount of signal was getting through. I missed this on my breadboard. So the pot still has a bit of resistance even at the end of its travel. (0-129) So I tried turning the pot off which failed miserably because I had wired the pot with terminal b as input ! So I reversed the A+B terminals and got a new pcb made. Turning the pot off at power up now worked but terminal A was floating to ground and so the input voltage caused the digital pot to latch up and put out a broken up signal ! So I now power up the digital pot with a value of 1 (not off) and this charges up the input capacitor to 2v5 and stops the break through. The pot can then be switched off completely when the volume equals zero. What a carry on to get something that I thought would be simple to work. The datasheet says clearly that the A+B terminals can be used any way round which isnt true. Microchip seem to just say they are looking into it and it has now been a number of weeks.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#2 |
"Beware Digital Pots"
I always have. Never liked them. Far prefer a motorized if remote is desired. Doc
Ne timeas a facie mulierum ea ignorare |
| Digital pots, better or worse than analogue pots ? | nigelwright7557 | Parts | 8 | 25th October 2011 05:10 PM |
| Help needed with digital pots | poodina | Digital Line Level | 0 | 30th March 2009 08:25 AM |
| Digital Pots | Dynsdale | Tubes / Valves | 5 | 14th September 2005 04:02 AM |
| digital pots | xplod1236 | Parts | 5 | 27th April 2004 08:50 AM |
| Digital Pots in 5.1 System | abid_rehan | Chip Amps | 25 | 20th April 2004 08:07 AM |
| Page generated in 0.07652 seconds (69.63% PHP - 30.37% MySQL) with 10 queries |
