Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 1st December 2011, 05:02 AM   #1
erin is offline erin  Australia
Default Testing the monotonicity of a DAC
If I want to observe on my oscilloscope, the monotonicity of a DAC chip,
I thought that if I generate a half sawtooth waveform using some audio software (like audacity etc.) with a duration of say 60 seconds, and the signal starting at -180 degrees crossing 0 degrees at 30 seconds and ending at +180 degrees at 60 seconds, I should be able to see any major non linearities as an unexpected increase or decrease in the DC voltage output of the DAC.
Can someone advise if this is a good way to do this or if there is a better way to do this test with a really good visual indication of non linearity.
Erin
Old 1st December 2011, 05:15 PM   #2
Wayniac is offline Wayniac  United States
Wayniac's Avatar
Great! The results of a two-channel subtraction (invert + add) plot would also be interesting to see.
I laugh at your puny tubes.
Old 2nd December 2011, 11:48 AM   #3
oshifis is offline oshifis  Hungary
Actually I have done it:
DAC linearity test CD
This method tests Dynamic Non-Linearity. You can use the sawtooth method, but I am afraid you won't be able to see the 65536 steps on an oscilloscope, and what you will see is a straight line in any case.
Old 2nd December 2011, 05:01 PM   #4
Originally Posted by erin View Post
If I want to observe on my oscilloscope....with a duration of say 60 seconds...
Do you have a digital memory oscilloscope with linearity substantially higher than what you intend to measure?
Old 3rd December 2011, 10:20 AM   #5
No, its an analog scope. I didn't want to "measure it", I just want to see some deviations.
I think the test CD by oshifis, should do the job.
Perhaps oshifis would be kind enough to explain how he generated the signals on his test CD?
Old 3rd December 2011, 08:03 PM   #6
I used a hex editor
songs for comparing/testing DAC meezger_seep Digital Source 0 28th December 2007 10:15 AM
Testing for new DAC. tube-lover Digital Source 1 18th March 2007 02:45 PM
Searching the better DAC testing all audiodesign Digital Source 10 1st July 2006 09:31 PM
DAC Testing Software Ulas Digital Source 8 30th April 2004 01:11 AM
Page generated in 0.08574 seconds (73.11% PHP - 26.89% MySQL) with 10 queries
