Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 13th February 2013, 06:21 PM   #161
Also, if you can listen to the link in iheart radio, the following post might help to figure out the stream URL
Audio/video stream recording forums - View Single Post - Record Clear Channel radio stations (iheartradio.com)
Old 15th February 2013, 07:46 PM   #162
merlin2069er's Avatar
Send a message via MSN to merlin2069er
lol, I'll need a flash plugin for raspberry pi.
Old 16th February 2013, 02:33 AM   #163
why not use Allwinner A10 platform? much better then this
Old 16th February 2013, 04:22 AM   #164
Send a message via AIM to DigitalJunkie
AFAIK,the pi doesn't support flash? But,I'd be happy to be wrong on that.
Pi tips I've gleaned so far: Jumper/replace the polyfuse(s),or otherwise bypass them.
I measured ~0.25V drop across the polyfuse on mine (Pi Model 'B' V2.0 ,single 1100ma polyfuse on the power input jack) with the system booted/idle. (~4.75Vcc,kinda low.)
Also,make sure your power supply is up to snuff. An ample supply of clean/stable 5V power is important.
After bypassing the polyfuse,and digging out a beefier 5V 3A supply,mine is much more stable.
I added some heatsinks on the chips,cause I happen to have some the right size. It dropped the temp by a couple-few degrees. Sitting a brushless PC fan on the table next to it,to blow some air over the board/heatsinks dropped another handful of degrees.
Without the heatsinks,It didn't seem to run very hot,even with some mild overclocking. If you're gonna get into more serious overclocking,heatsinks are probably a good idea,maybe even add a little fan too.
Tractrix in 1*Pi and 2*Pi revintage Multi-Way 21 26th August 2011 09:37 PM
Headphone Hub?? baronofhell Headphone Systems 3 26th May 2007 12:37 PM
centering hub for cdpro skyraider Digital Source 0 1st July 2005 07:08 AM
what to do with that old lan hub karma Everything Else 25 27th May 2003 05:58 AM
Barcode around CD hub? Circlotron Digital Source 0 13th February 2003 12:34 AM
Copyright ©1999-2013 diyAudio
