Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Raspberry Pi -A New DIY'ers Digital Hub?
Old 1st March 2012, 11:54 PM   #31
linuxworks is offline linuxworks  United States
linuxworks's Avatar
Originally Posted by mr_push_pull View Post
DJNZ
I'll never forget that mnemonic
LDIR!
My Photostream:http://www.flickr.com/photos/linux-works/
Old 23rd July 2012, 05:47 AM   #32
zog666 is offline zog666  Australia
Anyone got one of these and using it?
mine arrived a couple of days ago - and luckily "raspbian", a Linux distro with some raspberry pi specific optimisations has just been released.
The onboard 3.5mm sound output doest seem the greatest quality (understandable design trade-off, not a whinge).
Have tried 2 different USB dacs Behringer UCA-202 and AlienDAC, both work, but I was getting occasional blasts of white noise on the AlienDAC.
No serious listening yet, this is all in the very much "get it working without glitching" phase. Have my audio files mounted as network drives (NFS), running mplayer with cache setting.
Using an ALDI "ipad USB battery pack" instead of USB 5V plugpack sounds better..
so maybe a decent 5v usb power supply will help.
Currently experimenting with using it as a headless flacplayer, remote controlling from my android phone, getting OK results with the mplayer in the raspbian distro, and the "SSHmote" android app to remote control it.
FrontPage - Raspbian
SSHmote - The Linux Multimedia Remote Control | zokama.com
haven't tried this yet, but this looks interesting as well, and there are android remote control apps so I can drive it from my phone:
Raspbmc About
audio project blog http://www.minirig.org.au/
Old 23rd July 2012, 08:23 AM   #33
Atilla is offline Atilla  Norway
I got mine last week. I wondered a whole weekend where on earth am I going to find an SD-card reader and then I remembered I've got two of them at home and they're called digital cameras. Duh.
Raspbian launched the same day, pretty much which was great. I managed to boot it without a glitch and it's quite decent. HDMI output is working without issues, but I haven't managed to test the audio output. I don't have too great hopes about it though, but given how I've got ODAC, Bantam DAC and Grub DAC laying around, I don't think it's too much of an issue. They're equally microscopic.
One thing though - most peripherals are not usable on this device without an USB hub. The on-board USB can provide up to a 100ma and even for that you need a decent power source, which won't sag under the load. It's about a coin toss of a chance that anything you plug into the USB will work, so I'd recommend fetching some sort of a good USB hub if you intend to plug fancy things into it. The good part is that you can power the device itself from one of the ports on the hub (so I've read on the forum), which still means only one, good power source.
I've also managed to run OpenELEC - The living room PC for everyone on it with good success. I did a cross-compile and prepared an SD-card myself but there are people that provide almost daily builds, ready to be burned on an SD card, online.
That's it so far. I'll be hunting down a good usb hub and start preparing a living room media center with one of them.
Old 23rd July 2012, 09:01 AM   #34
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
Maybe this is a good situation for one of those ADuM4160 USB isolators.
Old 23rd July 2012, 09:25 AM   #35
Yeah, I've been checking them out lately. If you won't need the USB hub for anything else, this could easily be a solution.
Old 23rd July 2012, 10:55 AM   #36
Studio Au is offline Studio Au  United Kingdom
My plan is:
Raspberry Pi (using XBMC or Airplay)
Optical to MiniDSP DIGI
MiniDSP
MiniAmp (or better power amp)
I have all the pieces, just need to connect them all up.
Old 8th August 2012, 12:32 PM   #37
I've been tinkering with this on and off since I got it, but still have had glitchy playback with USB - as reported as a known bug by others.
.. it looks like just in the last week the USB playback bug has been sorted out... well I'm 3 tracks in with mpd and no glitch yet! - at least with onboard LAN playback
read here: https://github.com/raspberrypi/firmware/issues/19
info on how to add the bleeding edge firmware required: Raspberry Pi • View topic - New repository component for bleeding-edge firmware
further refs:
Raspberry Pi • View topic - usb audio glitches when writing to SD card
Old 15th August 2012, 03:58 PM   #38
linuxworks's Avatar
I finally ordered one. its about 1.5 months wait right now at newark.
my first use would not be for anything video related. I care more about controllers and network-engines, these days. its hard to imagine a better firewall/IP-stack/webserver than modern linux and so it should be a nice little web front-end for my controller projects.
should be interesting to compare against something like an arduino-mega. price is even cheaper for the linux board and software devel is MUCH easier than doing the arduino thing (been tearing my hair out with the stupid bootloader bug in the current mega 2560's! pretty useless as shipped and I'm about to give up on mega atmels.)
Old 17th August 2012, 05:30 PM   #39
mayhem13 is offline mayhem13  United States
MCM electronics now has them in stock.
Old 17th August 2012, 06:03 PM   #40
linuxworks's Avatar
cheers for the MCM clue! that will save me a lot of waiting time
Raspberry Pi -A New DIY'ers Digital Hub?Hide this!Advertise here!
Tractrix in 1*Pi and 2*Pi revintage Multi-Way 21 26th August 2011 09:37 PM
Headphone Hub?? baronofhell Headphone Systems 3 26th May 2007 12:37 PM
centering hub for cdpro skyraider Digital Source 0 1st July 2005 07:08 AM
what to do with that old lan hub karma Everything Else 25 27th May 2003 05:58 AM
Barcode around CD hub? Circlotron Digital Source 0 13th February 2003 12:34 AM
Copyright ©1999-2017 diyAudio
