Hi-resolution source 192KHz 24bit (USB to Analog) - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 24th December 2011, 06:32 PM   #21
ashaw is offline ashaw  Australia
That is because windows does not include a USB audio class 2 driver by default. You have to install one, and xmos did not write their own but rather decided to cross licenses one developed by someone else. Not due to any deficiency on their part.
Alexis Shaw
Old 25th December 2011, 06:36 PM   #22
Banned
Send a message via MSN to audiodesign Send a message via Skype™ to audiodesign
OK, I can find an USB audio class 2 driver but
Why you consider better teh XMOS ?
Old 25th December 2011, 08:29 PM   #23
UnixMan is offline UnixMan  Europe
UnixMan's Avatar
Send a message via ICQ to UnixMan
Because it uses the standard UAC2 Async protocol rather than a proprietary, block-transfer mode based protocol used by m2tech. For a discussion about why using block-mode is a bad idea (and the standard is far better), have a look e.g. at this post: Open-source USB interface: Audio Widget
Apart from this, Xmos will work (without extra drivers) on both MacOS and Linux. Which are far better systems to consider for audio reproduction. When it comes to high-quality audio, windows is a problem to avoid, not a viable solution.
"We should no more let numbers define audio quality than we would let chemical analysis be the arbiter of fine wines." N.P.
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 3rd July 2010 11:15 PM
Hiface USB -> I2S 24bit/192Khz audiodesign Group Buys 367 26th May 2010 12:00 PM
Upsampling to 24bit 192Khz surfstu PC Based 1 30th September 2009 02:24 AM
Using a PC as a source USB DA 24bit 192K lowtherdream Digital Line Level 0 27th September 2008 09:17 PM
Copyright 1999-2017 diyAudio
