Marantz CD-50 and CD-60, TDA1541, CDM4/19 - Page 51 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th January 2012, 03:20 PM   #501
Mayday is online now Mayday  Sweden
Originally Posted by UV101 View Post
Eh!! Cheap high esr!!!!
Yes. I was told that with ZLH and similar I should put a resistor in series with the cap.
The more you learn, the more you realize how little you know...
Old 7th January 2012, 03:25 PM   #502
Just found this on the TPR.
Link
Old 7th January 2012, 09:31 PM   #503
Actually i think i will be using a 7805 instead. It requires less components.
Old 7th January 2012, 10:02 PM   #504
Good luck and say what you think about the mod when you've done it
Old 8th January 2012, 11:18 AM   #505
UV101 is offline UV101  England
UV101's Avatar
Link
Yep, I've got a couple of his TPR boards here
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 8th January 2012, 11:33 AM   #506
TPR seems to be a lot of value for money, and the way I did it, also rather easy to build.
Old 8th January 2012, 01:02 PM   #507
I have just found one ac-dc adaptor that outputs 5v 2.5A. That saves me time and trouble. I hope i'll manage to hook it tommorow without too much damage to the pcb. I understood that i need to remove the resistor near the chip and connect the +5v oh the left of the resistor. Is it ok for the - terminal to be connected to the capacitor near the chip, as shown in the picture from 3 pages ago? Can I remove the resistor without extracting the pcb from the chasis? Thank you, and please excuse my english and my ignorance, but i'm new in electronics and diy. I have some knowledge in electronics, but i've never worked in this domain before. Best regards!
Old 10th January 2012, 09:04 AM   #508
Default feedback
Hi guys! I did not use the 5v dc adapter that i mentioned because it's a commutation source; i built one insted with the lm7805 and a few capacitors. The result....i was stunned. I don't know how to describe the improvement, but overall it sounds much better. I'd say the sound is much more clean and detailed. So far I have changed the op-amps and made the reg for the 7220 chip. What would you suggest for my next step? What is the 3-rd major improvement? Thank you and have a nice day!
Old 10th January 2012, 12:02 PM   #509
Swapping DEM cap, decoupling caps for the TDA1541A, Swapping smoothing caps before regs, swapping caps after regs. swapping caps around opamps to Rubycon ZLH, swap the bipolar caps on output to MKP axial 4,7uF or bigger.
Old 10th January 2012, 05:14 PM   #510
Power the new regulator with it's own transformer and then sort the clock.
Get the noise of the 7220 out of the players circuit completely and then stop it from doing any clock distribution.
Clocking the 7310, 7220 and TDA brings significant gains.
Far more than most mods mentioned.
May Day's points are relevant of course, cheap, fast and do help things.
If you want serious steps however you've got to do serious things !!!
Help is available - don't be scared
Marantz CD-40 (TDA1541A & CDM4): need help! Malefoda Digital Source 1 29th December 2009 02:29 PM
FREE Marantz CD-50 SE metal-plastic chassis (CDM4 based) happycat Swap Meet 0 7th June 2009 02:34 PM
Tube stereo for E 60 including TDA1541 cd player Westerp Tubes / Valves 3 27th April 2009 02:04 PM
FS: Ariston CD1 cd player, CDM4/19 + TDA1541A(si)+OPA627BP mudihan Swap Meet 13 6th July 2006 04:24 AM
CD-RW on CDM4/19 players.... Lyra Digital Source 3 25th May 2004 06:02 PM
Copyright ©1999-2017 diyAudio
