Marantz CD-50 and CD-60, TDA1541, CDM4/19 - Page 41 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 28th December 2011, 10:18 PM   #401
Mayday is offline Mayday  Sweden
Mayday's Avatar
I'll look into those schematics
Might not be necessary for the SAA7220, but those followed by a TPR could be a nice supply for a clock.
The more you learn, the more you realize how little you know...
Revived my blogg
Old 29th December 2011, 03:56 PM   #402
Mayday's Avatar
Arrived today, extremely well packaged incl. ESD-protection.
Revived my blogg
Old 29th December 2011, 06:09 PM   #403
UV101 is offline UV101  England
UV101's Avatar
The whole of the Teradac clock is the power supply except the oscillator and the counter chip!
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
GValve Pre, GFA-5500 Class A power, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 29th December 2011, 07:04 PM   #404
Mayday's Avatar
I didn't mean the Clock I've bought, I ment for just an oscillator if I needed to build a cheap Clock sometime.
Revived my blogg
Old 29th December 2011, 08:11 PM   #405
If you can build one as good and cheaper than this ( and it has to work btw ) I'll buy one off you !!
Old 29th December 2011, 08:14 PM   #406
They didn't send me a free BIC lighter either...
I'm going to complain and get a refund
Old 29th December 2011, 08:20 PM   #407
Mayday's Avatar
Probably not as good no
Revived my blogg
Old 29th December 2011, 08:21 PM   #408
Mayday's Avatar
You didn't!?! That's the new high-end BIC too!
Revived my blogg
Old 29th December 2011, 09:13 PM   #409
UV101's Avatar
hold on guys, what do you think most of the commercial clocks are?
You start with an accurate and stable oscillator ideally under 25ppm stability and you build the quietest PSU you can to power it with! That's it! well near enough!
The problem comes trying to obtain the oscillators. A lot of new stuff uses 24.576Mhz which seem to be available via RS in the UK. The other common frequencies 16.934Mhz and 11.2896 are not. The main problem with the Chinese clock is they use basic regulation and unknown oscillators.
You will definitely improve on that clock if you power the oscillator and counter chip from a TPR. The only problem you may have is that the oscillator may be 3.3v and the chip may be 5v.
Old 29th December 2011, 10:08 PM   #410
Mayday's Avatar
I was more thinking if I wanted do a basic clock upgrade for a friend or something.
I could then, I guess, use the TPR which is rather cheap to build and then simply hook it up to either existing oscillator or buying a better(?) cheap 1ppm oscillator of ebay?
Or am I completely stumbling around blind here?
On another subject, I've just glanced through the thread where Andrew did a "grundig" advanced DEM re-clock.
If I take 11.2896 from Valab clock to SAA7220 pin11, SAA7310-C pin28, /2 to to TDA1541A pin2 & pin4.
Lift pin9 on SAA7220 and I guess pin28 on SAA7310(by lifting closest component).
I then, assuming I'm right above, have to cut signal to Pin2 & Pin4 on TDA1541A from SAA7220..how?
I'm rather tired, and on painkillers for my ankle lol, but am I atleast close?
Revived my blogg
Marantz CD-40 (TDA1541A & CDM4): need help! Malefoda Digital Source 1 29th December 2009 02:29 PM
FREE Marantz CD-50 SE metal-plastic chassis (CDM4 based) happycat Swap Meet 0 7th June 2009 02:34 PM
Tube stereo for E 60 including TDA1541 cd player Westerp Tubes / Valves 3 27th April 2009 02:04 PM
FS: Ariston CD1 cd player, CDM4/19 + TDA1541A(si)+OPA627BP mudihan Swap Meet 13 6th July 2006 04:24 AM
CD-RW on CDM4/19 players.... Lyra Digital Source 3 25th May 2004 06:02 PM
Copyright ©1999-2017 diyAudio
