| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I've been experimenting with an N8 as a usb source ; 32Gb sd card + 16Gb internal, playing flac through Folderplay, using lipo to power a usb isolator and AMB y2 dac. Anyone else tried this ?
#2 |
How does it work? Are you happy with the result? Does Nokia provide their usb audio transport protocol as open source, or does it use industry standards?
#3 |
The sound is fine - I suspect it is limited by the 12.000Mhz clock the pcm uses. It sounds better than using the usb on my notebook and much better than the N8 audio jack. I haven't tried it through the hifi yet - just using HD650 headphones. It installs automatically and pretty much instantly using the usb-on-the-go cable adapter that came with the phone. All the equaliser, balance, etc, work but the volume doesn't - it can only mute. BTW you can add customised equaliser settings to N8 using Tunewiki although 99% of the time I don't use the equaliser at all. It is your last question that is the main reason for posting - I have no control over the software/driver in Symbian Anna so I wonder if anyone else has tried this and knows a hack, setting or whatever ? BTW I also tried it with Tenor Te7022L and it recognised and installed it but with an error saying not all functions supported - and audio is one of them it seems as I couldn't get music to go through the Tenor chip. Last edited by KlipschKid; 23rd November 2011 at 01:44 AM. |
| PCM2707, I2S out | 00940 | Digital Line Level | 27 | 25th June 2009 07:53 PM |
| PCM2707 I2S Data In | elec-tron2 | Digital Source | 0 | 13th March 2007 06:28 PM |
| Pcm2707 Usb->i2s | Rocky | Digital Source | 0 | 21st October 2005 01:35 AM |
| PCM2707 I2S out to TDA1541A DAC | TV Man | Digital Source | 3 | 4th December 2004 05:53 PM |
| Page generated in 0.06944 seconds (69.00% PHP - 31.00% MySQL) with 10 queries |
