| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I am in the progress to replace op-amps in my player. Mostly they are dual voltage dual op-amps, no problem. But there is one NJM2737, it uses single +5V power, wonder what is a better one to replace this?
Also, since all the op-amp are SMD/SOIC, I am thinking if there is something like DIP socket for SMDs? So I can solder the socket, and replace/testing out different SMD op-amps? Thanks a lot! |
#2 |
I hope that I understand the question.
Check out something called a surf board. There are lots of outfits that carry them and if you are looking to adapt a surface mount part to a dip socket that is what they are ment for. SurfBoards | Alltronics Also DigiKey carries them.
"You can keep your insurance baby nothing is guaranteed" -Tom Petty |
#3 |
I would be very careful as the NJM2737 is a micropower device.
You should be asking yourself "what is it used for and why was this device originally chosen"
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#4 |
Thanks for all the replies.
No, the Surf Board is not what I want, it converts SMD to DIP. My PCB is all SMT, so I want something doing the reverse, or more precisely, I want a device, that I can sold it on to PCB in SMD form, and than plug SMD IC (or may be DIP IC) into this device. For NJM2737, I probably have to leave it alone. It's the last stage of ADC which drives a PCM4202 ADC input. I suspect NJM2737 isn't a good one, but it's so small (in TVSP8 package), I am afraid I don't have enough good skill to replace it, it's tiny! |
| anyone suggest a good quality replacement for NJM2115 [3028U] OP AMP | at77 | Parts | 52 | 24th June 2010 10:44 AM |
| Good Souinding Direct Replacement For 325 / OP 37 | xtrprof | Tubes / Valves | 1 | 19th June 2007 12:09 PM |
| Op-Amp Socket | justpoor | Digital Source | 3 | 8th March 2005 09:23 PM |
| OP amp replacement | mieze245 | Chip Amps | 0 | 19th September 2004 06:46 PM |
| Page generated in 0.11588 seconds (79.65% PHP - 20.35% MySQL) with 10 queries |
