Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
DSD Playback system, DSF Player + USB DDC + DSD Amplifier
Old 23rd November 2011, 09:59 PM   #21
SoNic_real_one is offline SoNic_real_one  United States
I don't think power vacuum tubes would provide any advantage, sice you are using them as switches only. They are horrible when driven to saturation.
IMO, the DSD analog filter should be around 50kHz, slow slope... No need for 10GHz
Old 23rd November 2011, 10:23 PM   #22
KOON3876 is offline KOON3876
Hi Sonic, you noticed me that "Why it have to be Switch?". You are right.
I'm thinking dead_time control and I don't like dead_time control idea, it's not for the audio.
Maybe I can use good old analog circuit,
(a) logic out, volume(pulse height changed between 0V - 3.3V), DC cut C,
(b1) fixed gain 1Tr amp, diamond buffer Emitter Follower handles pulse, then + LPF.
(b2) Vacuum amp(no NFB) handles pulse, then it's output transformer is natural LPF.
By the way attached original 1kHz wav file "C:\TEMP\1KHz.wav"
and I converted to 1kHz.DSF by my program,
Then convert DSF back to WAV by KORG AudioGate. "C:\TEMP\KORG\1kHz.wav"
very little noise (below -110dB) was added, but should be OK.
and attached current source (dirty but anyway it works)
Old 23rd November 2011, 10:38 PM   #23
Analog power stage was my suggestion too...
But if you can switch MOS-FETs (and feed from power rails) at at least 2.8MHz, your aproach is valid.
Old 24th November 2011, 03:17 AM   #24
Please forget Post #22. that is because of 16 bit limit. (final digit error)
I made 44.1/24bit 1kHz Wav file
converted it to DSF format by my program
converted back to 44.1/24 WAV by KORG AudioGate
and there are no noise over -140dB.
I wonder my mistake.. I checked final WAV, and there was KORG Tag. OK I'm not looking same file.
0079142c|4c 49 53 54 46 00 00 00 49 4e 46 4f 49 43 52 44 | LISTF...INFOICRD
0079143c|0c 00 00 00 32 30 31 31 2d 31 31 2d 32 33 00 00 | ....2011-11-23..
0079144c|49 53 46 54 26 00 00 00 4b 4f 52 47 20 41 75 64 | ISFT&...KORG Aud
0079145c|69 6f 47 61 74 65 20 76 65 72 2e 32 2e 32 2e 31 | ioGate ver.2.2.1
0079146c|20 28 57 69 6e 64 6f 77 73 20 37 29 00 00 | (Windows 7)..
now I have nice quality PCM to DSD converter, I can add this function to my another programs.
(VST for crossover, ASIO driver, etc)
Old 24th November 2011, 02:50 PM   #25
That's more like it! Try a wav file that is higher in frequency, since DSD it has less capability there. A 22kHz audio sampled with 48 or 96 would be sufficient.
PS: 144 dB is the theoretical limit of PCM 24 bit resolution. No audio DAC on market comes close of that.
Old 24th November 2011, 04:38 PM   #26
So, now we have over 140dB (DAC - LPF)? DSD only needs LPF to get back to analog.
you just need low noise LPF
Old 25th November 2011, 02:04 AM   #27
There are several DSD to WAV program already, but I made for myself to study.
Frustrating Slow... Noise Level = -135dB. Simple, below 500 lines.
Old 25th November 2011, 04:00 PM   #28
OK 20kHz 24bit WAV -(mine)> DSD -(KORG)> 24bit WAV, still there are no noise > -140dB.
48/96 is not natural for DSD.. I can not convert them linearly.
Old 26th November 2011, 12:40 AM   #29
Yes, but you will see them in "nature"
Can you extend the graph past 22kHz or is a brickwall there in the Korg?
Old 26th November 2011, 02:39 AM   #30
Hi, I can not see over 22050, by WaveSpectra.
if I convert 88200/24bit wav, I will see noise curve attached "DSD_noise_Shaper.png".
(my program only handles 44100 now)
I set Zero point at 0.95, 0.74, 0.42 = 20947Hz, 16317Hz, 9261Hz.
These points and noise_floor are trade-off.
(noise lowered dB * lowered freq area) < (noise shaped dB * shaped freq area)
oh, KORG can handle 88/24. I tested 1kHz-88-24.wav to dsf to wav.
it shows -160dB range.
-101dB: 30000Hz
-88dB: 44000Hz
So, If I use LPF cutoff at 25000, 4th ButterWorth,
Then 44000Hz noise goes to -88dB - 10log(1+(44000/25000)^8) = -107dB.
maybe it's OK.
anyway I can not notice over 18500
DSD Playback system, DSF Player + USB DDC + DSD AmplifierHide this!Advertise here!
USB DSD DAC and ADC by ElectrArt alexcount Digital Source 70 15th May 2014 12:30 PM
Dsd without D/A stage.... kyrochan Digital Source 15 30th March 2005 04:36 PM
What does a DSD DAC actually do? Cameron Digital Source 3 20th August 2004 05:18 PM
New DSD D/A chip SteveG Digital Source 0 27th August 2002 06:16 PM
