| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I have an old BB3 laying around and started thinking about doing some mods to it. Maybe it can get a bit better, I sure hope so.
Started reading up on it, got hold of the service manual and quickly discovered that it was a bit too new to have the d/a chip that I really was hoping for, the classic 1541A. Nope, this beast has dual bitstream dacs, one handling the "left+" and "left-" -signals and the other dac does the same for the right channel. The signal then passes through no less than five caps to get rid of the noise, and then goes to diffrential amplifiers (lm627) to make the signal single ended. Phew! If I am going to be mad enough to try to convert it to a tube output stage, where on earth would be the best place to steal the signal? I am guessing after the lm627. This may be a good moment to laugh, as I am a beginner, but eager to know more. Maybe just easier to get an older cd to experiment on. But, the BB3 is "free" since I already got it, and there is sufficient room in the box to fit more stuff in it, so why not give it a try. |
#2 |
Magneto the Gravity Man
I tried a modified version of "Thorsten's" output stage with the Marantz CD63 with excellent results
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#3 |
Thanks for the input! Today I located a place closer to the chips where I can steal the signal. The place where I intended to take the signal in the first place seems like a bad idea, the signal was already amplified a lot there.
Where can I find a schematic? I am a beginner, but I do know how to follow a schematic. |
#4 |
Usually, the DAC will be a voltage output followed by some filtering before the opamp.
So before the opamp is the place for taking the signal unless you are into filter design. What are the DAC chips? Andy .
#5 |
They are SAA7321GP. I have located the outputs (two per chip), called INTL and INTR.
Any ideas if it matters which ones I go for? I guess it doesnt really matter as long as I use the same output from both chips so that they dont get out of phase. Where can I find out if it is a voltage output or current output? |
#6 |
If I have read correctly it is a voltage output.
Anyone with a good schematic? |
#7 |
I have now started this project by removing old rca jacks, drilled holes for the tube sockets. The power supplies are also soldered.
| Arcam Delta Black Box1 mods | ash_dac | Digital Source | 51 | 17th November 2011 07:44 PM |
| Need a schematic for Arcam Delta Black Box! | JiggaD369 | Digital Source | 7 | 26th April 2006 12:31 PM |
| Question: clocksynching: Linn Karik w Arcam delta black box 5 | charliecochrane | Digital Source | 0 | 24th March 2004 10:47 PM |
