Dolby digital to PCM converter - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 6th November 2011, 10:25 AM   #1
Default Dolby digital to PCM converter
I have this problem:
My TV has a OPTICAL DIGITAL OUTPUT that outputs PCM signal OR Dolby digital signal depending of the TV channel.
My HARMAN KARDON HK990 STEREO AMP has digital inputs that ONLY accept PCM
I need to put a module between them that convert DD to PCM and bypass PCM
I am not able to find this module ¿is there any in the market?
Old 6th November 2011, 11:45 AM   #2
The DD signal is usually surround signal. You need a surround receiver, maybe is time to upgrade.
There are modules that will DECODE the DD to analog signal, but I am not aware of one that will do a correct REMAPING from 5.1 to 2.0...
Old 6th November 2011, 12:02 PM   #3
¿UPGRADE THE HK990? this is a stereo system.
I am searching for a module doin this JOB (I think is a simple job transform DD into PCM)
Old 6th November 2011, 03:18 PM   #4
grael is offline grael  France
Are you sure your TV don't have a setting to output DD as stereo PCM?
It's a pretty common feature, my Sony KDL-40EX500 does this...
Old 6th November 2011, 04:43 PM   #5
my 42PFL7606 DOS NOT. I have contacted PHILIPS and they said they WILL NOT do it... no comments
Old 6th November 2011, 04:45 PM   #6
Pano is offline Pano  United States
Pano's Avatar
That's too bad. Every TV and DVD player I've seen has this feature.
Old 6th November 2011, 04:55 PM   #7
PHILIPS does not IMPLEMENT IT... so ¿what posible solution for extracting sound from tv?
- Scart does NOT WORK due to anticopy LAW
- SPDIF is not compatible with my digital INPUT
- Headphone out... horroble solution
I wa looking a module with TOSLINL input that made the change from DD into PCM...
Old 7th November 2011, 03:50 PM   #8
tiefbassuebertr's Avatar
Good topic. But I would formulate the question more generally:
How do I get from any multi-channel digital signal a high-quality two-channel down-mix (of interest for all user's, that have a lot of multichannel discs but no space in the listening room for a multichannel equipment (i. e. only two loudspeakers for stereo) ?
Fact is, a lot of Blu Ray discs don't offer selection for two channel mode resp. only in bad quality.
I don't understand this term:
"REMAPING"
Old 7th November 2011, 11:45 PM   #9
Well... with Dolby Digital you have 5 audio channels plus 1 for Low Frequency Effects.
He wants to send those into a stereo amplifyer (2 audio channels). He can choose to send just the L and R channels, but he will miss the voice (Center) and effects/music (SR, SL).
He can add the SR to R and SL to L (but that will increase the level too much). And the Center channel needs a different treatment.
That's why you need to remap the channels. Present continuous would be "remapping" if you are grammar police.
Old 19th March 2012, 10:30 PM   #10
If you not have to use digital input(I know this will the preffered solution), you could use a Gefen box like this:
Gefen, LLC - GefenTV Digital Audio Decoder
PC based digital crossover with dolby digital live preiter PC Based 64 25th April 2012 08:14 PM
coding your own PCM to PWM converter? jwagnerhki Class D 2 15th November 2005 09:06 PM
Intersted in SM5819AF DSD to PCM converter? oehlrich Group Buys 0 19th September 2004 01:04 PM
Dolby Digital..... bimbla Digital Source 3 31st March 2004 09:02 AM
Dolby digital 5.1 and decoding... scottylans Digital Source 5 22nd November 2002 03:13 PM
Copyright ©1999-2017 diyAudio
