Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
SPDIF out from DVD/BD player to 2-CH DAC instead Multi-CH Processor - what happes ?
Old 3rd November 2011, 11:41 AM   #1
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Default SPDIF out from DVD/BD player to 2-CH DAC instead Multi-CH Processor - what happes ?
I observe in some cases, that no analog signal is present in such cases.
But OTOH - in some cases there is an analog stereo signal present, even in such cases, where on the BD or DVD is only DTS 5.1 or "Dolby Digital" (and no "Dolby Stereo") mentioned.
What must be the correct behaviour?
Is this behaviour also dependend from the implemented multichannel decoder software (in context to the behaviour of the S/P-DIF receiver chip e. g. CS84xx) or only from the audio codes on the discs resp. from the broadcast television station?
Thank you for your advices.
Old 4th November 2011, 06:16 PM   #2
kimk is offline kimk  China
可能播放器内部把杜比或DTS多声道合并为立体声了.应该有声音设置菜单查询到,也可能光碟内容本身的声音 就只是立体声音频,而非DTS或杜比多声道..
Old 5th November 2011, 11:43 AM   #3
Possible players within the Dolby or DTS multi-channel into a stereo. Should have the sound settings menu to check, it may sound on the disc content itself is only stereo audio, rather than the multi-channel DTS or Dolby ..
Thank you for your advices, but the losses by google translate are too large.
Old 5th November 2011, 01:20 PM   #4
SoNic_real_one is offline SoNic_real_one  United States
That is imposed by the licensing... High res audio is banned at SPDIF output. Sometimes you can get it working by allowing to be down-converted - check the manual.
Old 5th November 2011, 01:49 PM   #5
Thanks. The follow possibility could be a solution to get high resolution audio at the SPDIF in all cases:
Pioneer DV-575A, -578A, -585A und -588A Hires SACD und DVD-A digital output Bausatz
(only in German language available).
Old 5th November 2011, 01:50 PM   #6
Yes, basically something like that can be done on most of the players.
SPDIF out from DVD/BD player to 2-CH DAC instead Multi-CH Processor - what happes ?Hide this!Advertise here!
Active Crossover using PC and multi ch. Soundcard? vision Digital Source 22 7th July 2012 11:59 PM
hdmi to analog? 8 CH USB DAC? malle Digital Line Level 5 9th January 2009 09:30 PM
Temp Variations CH to CH Zero Cool Everything Else 0 4th February 2007 01:25 PM
bridge a 4 ch amp into 3 ch? batonrye Car Audio 8 17th August 2004 10:37 PM
Pioneer DV-939A multi region DVD(A) player bigparsnip Swap Meet 0 28th November 2003 12:54 PM
Copyright ©1999-2017 diyAudio
