| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Some time ago I designed a USB isolator, with ADUM4160 as the base of the project, for my sound card measurement system . I also added a dedicated power supply and, to make it more universal, isolated DC/DC converter (ADUM5000). ADUM4160 supports 12Mbps communication which is sufficient for 96kHz/24bit sampling rate.
Isolator works very well. Red line represents the measurement of the EMU soundcard connected directly to the USB port of my laptop and black using isolator. As you can see 50Hz hum and the second harmonic is filtered better. There is also less noise in the 2kHz - 20kHz band. |
#2 |
Nice!
I've had both these IC's for a couple years now and still haven't attempted to make a board. Do you plan on selling PCB's?
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#3 |
I've used this USB Isolator Board from Circuits@Home for a few months now and it works great. You can really hear the improvement in the audio quality as the USB-borne noise is stripped off. It uses the ADUM4160 also:
USB Interfaces « Circuits@Home |
#4 | |
The next version will be smaller (without switches - I used them only for testing). |
#5 |
This all looks really nice, but with all of the high resolution Dac's at the moment, everybody is waiting for ADUM devices that support more then 12Mbps.
Does anybody know if somethings is on the roadmap? |
#6 | |
I still might keep the dream alive of building my own design some day. I would like a version that is as small as possible without any provisions for external power.
#7 |
is allready there, with PSU isolator included.
It works fine, i have one. But does not work above 88,2 Khz USB Isolator, Galvanic Isolated USB 2.0 - Electronics-shop.dk |
#8 |
#9 |
Remember that all devices (computer → USB → DAC) share the same ground which causes flow of small currents, and these can cause the appearance of distortions in the analog part of DAC.
#10 |
Hmmm... NO. Digital levels are way higher than those "noises", therefore are immune. You are thinking in analog terms.
Also FYI, currents CANNOT flow on just ONE conductor. They need a return path to source, a closed circuit. Last edited by SoNic_real_one; 2nd November 2011 at 11:16 PM. |
| PC controlled via USB 6 channel audio mixer with digital volume controls | nigelwright7557 | Vendor's Bazaar | 1 | 3rd November 2011 02:54 AM |
| Perfecting the USB Isolator | ggking7 | Digital Line Level | 31 | 3rd October 2010 08:24 AM |
| USB Isolator - ADuM4160 | Ekkeri | Digital Source | 2 | 2nd March 2010 08:17 PM |
| Looking for optical isolator for audio | FastEddy | Solid State | 0 | 27th September 2006 05:40 PM |
| USB digital audio transciever | jwb | Digital Source | 6 | 10th December 2002 10:46 AM |
| Page generated in 0.10797 seconds (80.22% PHP - 19.78% MySQL) with 11 queries |
