| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hello all, I'm wondering if anyone has got ideas about where to start and what to change on this pre 98 DAC 3?
All advice gratefully received Cheers Dave
#2 |
Does it have the YM3623->DF1700->2xPCM63 chipset and to what extent do want to modify it ?
ray |
#3 |
Hello Ray, thanks for the reply, yes it has the ym3623b, df1700p and pcm63p chipset, well i'm a begineer at this althuogh the pcb layout is straight forward and i can use a soldering iron, so swapping bits is no probelm. i just don't really know where to start or how good the dac can get, so maybe some minor tweaks for now, it seems this is a dacdig rev 2 from 1993 with sovtec 6922 valves and jensen paper caps,
thanks once again, dave |
#4 |
I have one of things in pieces at the moment and I am not too sure what to do with it. I tried the no oversampling route but I was not too impressed though with hindsight there is one thing I would now do differently. On the analogue side I always felt the relatively high output impedance and limited output current was holding the dac back but the limited space has stopped me doing anything about it. Sorry to be of little help but I have only seen references to mods for the newer non os audionote dacs. The only other reference to the oversampling audionotes I have seen is here;
cd/dac mod..picture!! You might try posting in the digital section of the audioasylum www.audioasylum.com where Mr Audionote, Peter Qvortrup is to be found. ray. |
#5 |
DIY !
The NPC SM5813 Filter-chip is supposed to sound better than the DF1700, and is a direct replacement...
Arne K
Ars longa, vita brevis |
#6 |
The SM5813 is the DF1700 and both have long been discontinued.
ray. |
#7 |
DIY !
#8 |
Fitting the SM5847 using a daughter board would be far better option.
ray. |
#9 | |
Probably yes, I have such board repling the 5842 regards |
#10 | |
May I humbly suggest to add my DAC clock reclocking board ? It lowers the jitter of the regenerated clock hence will bring resolution, for sure..... regards |
| New Audio Note M10 | Audiohifi | Tubes / Valves | 19 | 24th June 2009 09:10 PM |
| audio note DAC-KIT 2.1 | drobert | Digital Source | 0 | 24th October 2006 06:28 AM |
| FS: Audio Note TRANS-010; Audio Note 20H 50mA choke; Black Gate Wk "power tank" | Joseph0 | Swap Meet | 1 | 24th May 2006 05:17 AM |
| Audio Note Kageki vs. EAR 859 vs. Audio Innovations: The First | Vortex | Tubes / Valves | 1 | 2nd February 2004 12:31 AM |
| Audio note dac | Kovax | Digital Source | 9 | 17th February 2003 03:33 PM |
| Page generated in 0.12454 seconds (78.61% PHP - 21.39% MySQL) with 10 queries |
