Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
single end out for balance output DAC like PCM1794 question
Old 20th October 2011, 05:03 PM   #1
pdcaceo is offline pdcaceo  Hong Kong
Default single end out for balance output DAC like PCM1794 question
HI All,
I got a question.
There are many DAC is balance output + and -.
In many application they need to use opamp to mix up to single end out to have better S/N.
I question about If I only take + signal only and all is single end design.
My idea is SE is better than PP.
BTW, there are a DC on DAC output.
ANy reference design can share??
Wilson
Old 21st October 2011, 04:40 PM   #2
nightuser is offline nightuser  Russian Federation
I was interested in what answer you may receive. As there are nobody to help, I will try. If you are looking for new experience, you may try to load (-) output with resistor. (+) output with i/u converter with same input resistance. As I understand, you need to know how output stage looks like for answer yours question. Without schematic you can only make intuitive suggestions. Beware, output performance of DAC will be degraded if passive i/u stage used. Just have fun :-D
Old 21st October 2011, 05:18 PM   #3
jcx is offline jcx  United States
differential output reduces noise from common gnd, supply coupling of the digital circuits in the DAC
it can also give lower distortion, and improves S/N
I don't understand your SE vs PP concern - that juxtaposition would usually refer to circuit bias for Class A operation
the conversion of a differential to single ended signal has nothing to do with push-pull operation or "single ended" bias
you can use all Class A circuitry, single ended bias too if you want in the I/V and differential to single ended Signal conversion
even with op amp I/V - the 6.2 mA center bias of the PCM1794 causes op amp I/V to operate Class A
you can add a ccs load to the summing op amp output too if you think it helps
Old 22nd October 2011, 12:13 AM   #4
Thanks for yoyur reply.
Oh, yes, it is differential. I question about the performance of summing amp. It need to mix + and - signal. So, I think it is loss signal in here.
So, I am think only take + signal. The concept just old old version TDA1541A.
Wilson
Old 22nd October 2011, 12:57 AM   #5
Zero Cool is offline Zero Cool  United States
Zero Cool's Avatar
Well...You could do a passive I/V conversion of both the + and - halves using a resistor to ground from each phase. Then just take a signal from the + side and ground through a buffer of your choice. BUT after looking at the ground contamination around the DAC chips from all the digital noise...I sure wouldn't think it would sound very good!
You would have to have a VERY carefully designed PCB to have the output be quiet enough for single ended operation.
Zc
P.s. (by PP I think he means differential)
It's not about what you can BUY...It's about what you can BUILD!
Old 22nd October 2011, 01:47 AM   #6
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
I used my first hand made PCM1794 DAC single ended before I got around to making an I/V stage. Just used a single resistor to ground as suggested above.
It definitely didn't sound bad, but there was some noise due to the fact the output level was so low I had to raise the gain of the amp.
Old 22nd October 2011, 03:13 AM   #7
I suspect you have spent too much time reading Audiophile nonsense and don't actually understand the circuit theory well enough to make that judgment
I wouldn't use the exact circuit in the data sheet but that is how the performance of the DAC is measured, to get the S/N and distortion numbers - if you understand the numbers you should see there isn't much the DAC is supposed to be doing that is "missing"
just using one side will have more noise, distortion than combining both in a decent active circuit
if you insist on a "audiophoolish" method then you could use a transformer to convert the differential signal to gnd referenced - but any transformer will add low frequency distortion that is easily measurable
Old 22nd October 2011, 07:41 AM   #8
Calvin is offline Calvin  Germany
Calvin's Avatar
The PCM179x series of BB features such low distortions and noise, that its no trivial task to build a following stage that preserves that technical quality.
It may be the topic of endless discussions if a couple of dB plus or minus around -100dB is any more than just academic porn.
It for sure doesnīt say anything about sonic merits of a circuit.
Of course is a SE stage more prone to inferior layout design, ground issues etc. but then this doesnīt tell a thing about sonics either.
In any case itīs no issue to use just one of the PCM179x outputs in SE style.
You need to make sure that the second output sees an equal and low impedance.
You could either use two identical circuits like the ones in the attachment and take just one of two outputs, or connect a smallish resistor of 2-20Ohms from the second output to gnd.
Since the output of the attached circuits is free from dc it may be directly coupled to a buffer stage or a following device.
The left circuit requires well regulated clean power supplies, especially the positive supply.
The right circuit lessens the demand on the positive power supply at the expense of slightly more touchy setup, a bit more noise and slightly increased THD.
The left circuit is capable of THD better than -90dB (at fullscale) and better than -110dB in noise. But best is...it blows away OPamp-IVs within seconds.
See also the thread "ZEN -> CEN -> SEN, evolution of a minimalistic IV converter"
jauu
Calvin
Old 22nd October 2011, 02:41 PM   #9
SoNic_real_one is offline SoNic_real_one  United States
That is just wishfull thinking at best. SE from 179x it just blows, that is it... Increased distortions, reduced dynamics, increased noise - all due to SE, resistor aproach.
Also those circuits above are very picky about adjustments, picky about components.
Old 22nd October 2011, 06:28 PM   #10
Calvin's Avatar
talk about Your wishes not mine. The given values were measured with an R&S UPL and are consistant on a series.
And no, they are not picky to adjust and require just easy to source īstandardī parts.
jauu
Calvin
single end out for balance output DAC like PCM1794 questionHide this!Advertise here!
Output Transformers for 6L6/5881/EL34/KT66 single end Musik007 Twin Audio 3 23rd February 2013 03:24 PM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 4th July 2010 12:15 AM
Good circuit for single end in to balance out? niner Pass Labs 6 3rd February 2008 01:31 PM
Copyright ©1999-2017 diyAudio
