| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi all. I am a DIY tube guy and a decent electrician but I am starting to get the digital bug. I purchased a NOS DAC off of Ebay. It is called a muse mini DAC and I believe that some of you are familiar with it. It is the one with four DAC chips (TDA1543s) I have some plans for the little DAC as far as modding goes and I have a couple of dozen questions.
Firstly I don't use optical inputs so I was going to remove the optical input and jump out the pad to go with SPDIF exclusively. What I would like to do is have two coax inputs and be able to switch between them. I am somewhat of a minimalist and I think that a good quality switch with gold contacts should do this with no problem. Here is the candidate that I have in mind:Digi-Key - 450-1382-ND (Manufacturer - TT11DGPC9T1/404) Secondly I would like to improve the regulation by adding a couple of Burson Super Regs in place of the regulators that are on the board and lastly I want to feed it a relatively clean 12v with a little kit from Glassware which is just a simple regulator using a LD1085P. I want to mount all of this in either a different single enclosure or two separate enclosures for the power supply and the DAC respectively. Later I may try Film caps on the output instead of the electrolytics and upgrade some of the other components. Am I off base on any of the things I want to do?
Gavin |
#2 |
Nobody huh? Well I just ordered a whole bunch of parts and I'll let you know how it turns out.
Gavin |
#3 |
head-fi (Mini Dac TDA1543 X 4 NOS)
importantly, use 9v depending what they ended up putting on your board. |
#4 | |
Also 1543 are very cheap/poor performance DAC's (THD+N= -75dB, SNR= -90...95dB), even using four of them is not ending up that great in the THD part (helps only the SNR part). Especially followed by passive I/V, tubes and no filtering stage... I don't think will be anything exciting. Last edited by SoNic_real_one; 22nd October 2011 at 05:37 AM. |
| Muse USB DAC - Any experiences | matherp | PC Based | 1 | 11th December 2009 10:08 AM |
| DPA little bit dac modding (7350 dac, ym3623b receiver) | ash_dac | Digital Source | 16 | 5th December 2007 07:09 PM |
| Modding the **** out of a kenwood KD2055, need platter/motor/bearing ideas | 240z4u | Analogue Source | 2 | 11th July 2007 03:42 AM |
| Owners manual needed, MUSE MODEL ONE | audiofanatic101 | Solid State | 1 | 8th May 2007 07:06 AM |
| Page generated in 0.08318 seconds (73.76% PHP - 26.24% MySQL) with 10 queries |
