Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
MiniMax DAC - best opamps to replace stock ones?
Old 21st October 2011, 01:09 AM   #31
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
MiniMax DAC - best opamps to replace stock ones? Send a message via Yahoo to vdi_nenna
AD827 $10-$40 on eBay.
http://www.ebay.com/sch/i.html?_trkp...4&_sop=3&_sc=1
I build, therefore I am.
Old 21st October 2011, 01:22 AM   #32
Audio Maniac is offline Audio Maniac  Brazil
Very interesting book! Has someone read it?
Originally Posted by SoNic_real_one View Post
Hint: emitter degeneration
Book.
Old 21st October 2011, 01:25 AM   #33
I am thinking of purchasing the op-amps on eBay. Is there any risk of buying fakes ones? I mean, does it exist fake op-amps (LM4562, OPA627, AD797)?
ad827 | eBay
Old 21st October 2011, 01:50 AM   #34
alant4321 is offline alant4321  Canada
alant4321's Avatar
Basically, IC OPAMP NE5532/NE5534 is nothing wrong. Both Musical Fidelity in UK and MBL in Germany currently use it in audio amplifier design and sell it at many $$$bug. They do not solely plug and play, but use a set of “jig and fixture” to perform testing, sorting and component matching of IC OPAMP before use. Thus, it sounds good. However, the methodology of component matching may be secret to the company.
Alternatively, IC OPAMP LM4562, OPA627, AD797 are good choice, but higher price in comparing to NE5532/NE5534. I do not comment eBay, but recommend more reliable suppliers such as Digitkey, Farnell or Mouser, etc… in which the component must not be fake.
"To work smarter, but not to work harder." by alant4321
http://www.teco-audio.com
Old 21st October 2011, 01:54 AM   #35
SoNic_real_one is offline SoNic_real_one  United States
Try Digikey, Mouser, Avnet...
LM4562 is some 3$ for DIP, 1.5$ for SMD. The metalic can is expensive - some 20$ - and I don't think it is worth it.
Try also AD8599 - really a good OpAmp, on par with LM4562.
More from it:
http://www.eetimes.com/design/audio-...s?pageNumber=3
Old 21st October 2011, 02:39 AM   #36
counter culture is offline counter culture  United States
When you've installed the sockets, get somebody to swap the opamps without letting you know which ones they've put in. See if you can reliably identify any of them over a number of swaps.
Many people insist they can hear differences, but many others think that there's no audible difference; TI, who manufacture highly regarded DACs, recommend NE5532s and NE5534s for use in the very applications where you are intending to replace them. Most of the people making recommendations NEVER undertake the unsighted comparisons, they rely on swapping the chips themselves... ...and stuff that people write in threads like this one.
Old 21st October 2011, 03:10 AM   #37
Michael Bean is offline Michael Bean  United States
Michael Bean's Avatar
AD827 - $12.47:
Digi-Key - AD827JNZ-ND (Manufacturer - AD827JNZ)
By the way, using a socket in this type of circuit may have a detrimental effect on sound because of stray reactance conflicting with high frequencies and fast rise times, it's best to solder the opamp directly into PCB. Afterwards, proper circuit performance needs to be verified using an oscilloscope.
Mike
Old 21st October 2011, 07:44 AM   #38
Alant4321, Sonic_Real_One, Counter Culture and Michael Bean,
Thank you very much indeed for your contributions! I'd like to say I relly enjoy this forum. Some time ago I got unexpected results with an ordinary Radio Shake integrated amp due to precious info given here. That encourages me to go further and modify my new DAC.
MiniMax DAC comes with IC socket but after choosing the best op-amp, I'll solder it on the PCB. I haven't got a scope and I don't plan to buy one, but I may pay a guy who modifies audio gears to test the reability of the chosen op-amp before soldering it.
I'm quite ceptical as regards some audio tweeks, such as "magic" power and digital cables and I'm certainly performing blind audition tests to avoid "placebo effect".
Old 21st October 2011, 10:55 AM   #39
Personally I did a test replaced on My Denon only ONE OpAmp. That was taking care of the front and rear R channels (they kept the L and R separated - good job).
At that point I really wasn't sure which speaker is that channel and I was able to pick up a "winner" after a few songs that I knew very well (to make sure). The channel that sounded best was the one with the new OpAmp.
Denon uses better OpAmps in the end-of-line players, receivers. Is a way for them to make a marketing difference and ask for twice the price.
A lot of companies used the 5532 simply because it was (and still is) the best CHEAP OpAmp that you could get - good for the beancounters.
TI recomands that for some DACs because they knew that japanese electronics design people (culture) would be inclined to pick up a DAC for their designs if it did have 5532/5534 shown. But is not the only one shown in their data sheets...
Old 3rd January 2012, 10:36 PM   #40
bobsherman is offline bobsherman  United States
[QUOTE=Mooly;2752167]The AD797 is one that needs care... it might have stability issues as a drop in replacement.
Keep it simple... the OPA2604 and LM4562 should be fine. For a single opamp for the output I would have an OPA604 to hand.
Hi Mooly,
You seem to like the OPA2604. Have you tried the LME49990? Any opinons?
regards
Bob
MiniMax DAC - best opamps to replace stock ones?Hide this!Advertise here!
Eastern Electric Minimax Tube DAC w/ 9018? Kenobi Digital Line Level 12 13th November 2011 10:06 AM
Mint Eastern Electric Minimax DAC Ultralight Swap Meet 1 16th October 2011 10:01 PM
Replace opamps in Philips 963SA sacd player Ed Fallon Digital Source 0 11th April 2003 04:00 AM
Copyright ©1999-2017 diyAudio
