MiniMax DAC - best opamps to replace stock ones? - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 20th October 2011, 01:11 AM   #21
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
Originally Posted by SoNic_real_one View Post
LM4562 has a special input stage, is not a plain jfet.
Right, its not any kind of jfet, its bipolar.
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 20th October 2011, 01:42 AM   #22
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
its bipolar
I couldn't find this in any of the spec sheets. Thanks.
I build, therefore I am.
Old 20th October 2011, 01:50 AM   #23
abraxalito's Avatar
The 'giveaway' in a datasheet to distinguish bipolar from FET is the spec for input noise current. LM4562 shows this as 1.6pA/rtHz. A JFET opamp's figure for this is orders of magnitude lower. Take the OPA627 as a comparison, its 1.6fA/rtHz.
Old 20th October 2011, 04:50 AM   #24
Based on Diyaudio's comments, ESS Technology's "Sabre Aplication Note" and Douglas Schrodeder's articles, I have decided to try the following op-amps:
OPA2604 (I/V conversion and LPF filter) + AD797 (output)
LME49720 ou LM4562 (I/V and LPF) + LME49710 (output)
dual mono OPA627 (I/V and LPF) + OPA627 (output)
I would like to thank all of you who made those helpful contributions in this thread.
Greatings!
http://www.esstech.com/PDF/Applicati...PCB_Layout.pdf
UPDATE 1/18/2011: Eastern Electric Minimax DAC - upgrading op-amps Review - Equipment Reviews - Dagogo
Audio Blast: Eastern Electric Minimax DAC Opamp Rolling - The Columns - Dagogo
Old 20th October 2011, 07:24 AM   #25
qusp is offline qusp  Australia
qusp's Avatar
I suggest also trying the lme49990 (output) and opa827 (input), these weren't around when the sabre app note was generated, well perhaps the opa827 was. 827 is jfet input, lme is bipolar
Old 20th October 2011, 07:40 AM   #26
Mooly's Avatar
The AD797 is one that needs care... it might have stability issues as a drop in replacement.
Keep it simple... the OPA2604 and LM4562 should be fine. For a single opamp for the output I would have an OPA604 to hand.
I have also used the AD845 with excellent results.
If the original is an NE5534 you need to check if an external compensation network (cap) is fitted between pins 5 and 8 and remove it.
Installing and using LTspice IV. From beginner to advanced.
Old 20th October 2011, 01:31 PM   #27
Hi Mooly! Thank you again!
I'll do it then. Taking into account it's not cheap and your warning, I'll avoid it.
Qusq, I'll study about the LME49990. In Schrodeder's article, it was used on MiniMax DAC. Thx!
Old 21st October 2011, 12:12 AM   #28
But is not plain bipolar either
Old 21st October 2011, 12:46 AM   #29
Hint: emitter degeneration
Book.
Old 21st October 2011, 01:20 AM   #30
Michael Bean's Avatar
I've used the AD827 for I/V conversion with great results, only caveat is power supply bypassing and circuit layout are very important with this chip. Get it right and nothing, not even discretes sound better.
Mike
Eastern Electric Minimax Tube DAC w/ 9018? Kenobi Digital Line Level 12 13th November 2011 11:06 AM
Mint Eastern Electric Minimax DAC Ultralight Swap Meet 1 16th October 2011 11:01 PM
Replace opamps in Philips 963SA sacd player Ed Fallon Digital Source 0 11th April 2003 05:00 AM
Copyright 1999-2017 diyAudio
