| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
This picture show the music waveform taken at the line level
output of a Marrantz CD5000 CD player. At the instant when the shot was taken, the music is going through some loud passages. The vertical display of the scope trace has been adjusted so that only 30% of the waveform is shown. I dont know if this clipping is due to jitter or other digital anomalies, but my guess is that it could be in the 1's and 0's that comes from the CD, ie it was recorded that way. Would the squared off waveforms explain why sometimes when you listen to music and it gets to a loud passage, you ears can't stand the music and you instintively want to turn it down. So the fact that you want to turn it down is not because it is loud but because the playback music was distorted during the loud passages. This distortion take place at the source so even if your amp is not clipping, it is amplifying a clipped waveform. This is a relatively new recording (done in the last couple years or so) I assume using better recording technology etc.. because the CD sounds better/clearer than others that are 10 -20 years old. But it seems that there are still room for improvement at the recording studios. Granted, I only scoped this one CD, and may be other better recorded CD dont have this problem. And since only one or two wave forms out of hundreds (in that instant of time) are clipping the resultted music sounded good, with just a hint of harsheness. So when you are listening to your CDs and encounter some harshness, especially when it gets loud, then before you start ripping your amp and preamp and speakers system apart trying to tweak it, put a scope on the CD output, the problem may be in the music! |
#2 |
another shot
#3 |
I'd like to know what scan rate your scope was set to. The waveform shouldn't look like that in the first place. Even if it was clippin, that doesn't even slightly resemble what we are looking for.
Also, the input on your scope might have not been attenuated enough. I'd imagine that the output on your marantz is fine. Check over the scope settings.
-- Duo, W1ngs, VA7MON, and lesser known handles. -- -- http://www.w1ngselectronics.com -- My Work and Projects -- |
#4 |
was set to 0.2 ms per division. The clipping waveform in the top picture
is about 1 division wide so that makes it about 5000 Hz. The bottom one is about 3 division so that makes it about 1.6 kHz |
#5 |
Which part of your picture is clipping ? I can't see what we normally know as clipping.
Unless your CD player is defective I think you should never be able to clip any of the analog components. With about +/- 12 volts ( typically ) and about 2 volts at 0 db output , you could never clip it with any signal from the CD. And clipping off the CD data stream ? - I have never heard of it ! Clipped individual instruments - I have never seen this but that might happen at the recording stage , not while transfer to the digital domain. In any case I can't see any clipped waveform on your screen. You should use a slower scan rate . Cheers.
AM |
#6 |
#7 |
Banned
I reccon.. I mean... what are we looking at?
shouldn't you burn a sign wave sweep onto a CD and play that?
#8 |
It is quite possible that the digital signal is "clippling" as any ADC with over-driven inputs will create a stream of 1's.
Anyone have an idea how to determine if the CD itself contains a stream of 1's? I'm thinking that there must be software that can show the binary stream as audio "plays" off a disc. :)ensen.
Those who claim to be making history are often the same ones repeating it. |
#9 |
For me the image taken by the scope is no surprise . I read about that a good article in Elektor 2 years ago or so .
The maker of the article did same experiments with a scope and took some of the album from Gloria Estefan passages . It showed clearly the same waveforms , and the author experimented same thing on some of Jean Michel Jarre CD recordings . So where is the fact ? There are many places the clipping can have been made . Sometimes it starts at very beginning of recording for each track , in case of a multi track recording , but mostly the evil is done later on into the recording process . The worst stade is at mastering sessions , before the engineerer sends the final tape to be mastered . The use of very sofisticated technology is never the assurance of a clean result , and every waveform is not analized so not to ensure lack of that problem . In fact , there are some tech rules for them saying such clipping is not HEARABLE if shorter than x milliseconds . That is not true of course but every mastering engineerer wants to maximize impact and high output levels so that sound is huge on the CD , very loud though . So , the resulting tape is a compromise . Here it could not result of analogue tape distortion but clearly indicates that the max input level in digital has been exceeded in the upper parts of the waveforms , in order to maximise output level . This is good for mass audio production , where some music destination seems not an audiophile system but popular mini-systems , where that problem would not be heard as such , regarding the indigence of dynamics,bandwith,transcient response and phase of such systems ( think about cafes, department stores, clothes shops etc etc . ) Of course , all that is really nasty for us , poor audiophiles , who take extra care and labour to really get clean results with expensive equipement - or extra diy labour ,
"... Audio needs the thinnest wire ..." Rowan McCombe ![]() "Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright
#10 |
first thing encountered after a microphone is often/always a compressor/limiter.
So.... what do you expect? A horn system (genre klipsch, avantgarde) can 'restore' a bit of the leftover dynamics, only because most modern studiomonitors (mostly B&W) sound a bit 'lazy' (in comparision) by nature. There are always some signs of 'life' left, even in the greatfull death. BTW marketing of bass boost systems and other spatializers, dsp-programs need a cause, don't you think. A healty patient is a bad doctor's client. |
| Triangular waveform | dead rat | Class D | 27 | 11th November 2008 05:54 PM |
| Waveform analysis | Conrad Hoffman | Equipment & Tools | 1 | 23rd March 2008 02:53 AM |
| Funny waveform! | ifrythings | Power Supplies | 19 | 31st March 2006 11:49 PM |
| help with zen waveform | jcayer | Pass Labs | 17 | 23rd February 2005 03:10 AM |
| Page generated in 0.11818 seconds (82.56% PHP - 17.44% MySQL) with 11 queries |
