Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 5th September 2003, 02:33 PM   #1
Default TDA1543 dac
I have seen a simple design using this chip in a few places on the forum and it looks interesting. I do have a question if anyone can help. I understand it needs i2s input. If i have an old cd player with 11.2mhz clock and 7310/7220 chipset, can i use this as the i2s source or is it at the wrong clock frequency?
Old 7th September 2003, 06:03 AM   #2
Banned
Send a message via Yahoo to Elso Kwak
Cool Re: TDA1543 dac
Hi Rotellian,
Yes you can use the SAA 7310 as a source for the I2S signals if you want to construct a NON-OS DAC.
See Marco's site:
http://members.xoom.virgilio.it/hi_fi/q7310.htm
You need pin 2, 3 & 4 on the SMD package. Hope this helps.
Old 7th September 2003, 09:50 AM   #3
Excellent - thought so. That dac is ridiculously cheap - even in the uk! Be something fun to do Cheers
Old 9th September 2003, 04:44 PM   #4
Previously: Kuei Yang Wang
ThorstenL's Avatar
Default Re: TDA1543 dac
Konnichiwa,
If your player has the 7310 & 7220 it is almost invariably bound to have also a TDA1541. The TDA1541 is a much superior performance and soundquality chip to the 1543. So I would not recommend to "downgrade" the Player....
Sayonara
Old 9th September 2003, 04:57 PM   #5
Its a 7323 philips bitstream actually (nice midrange - terrible bass). But i do have another one with 7210/7220 that is in need of a new cdm4/19 (which i might just have found in another old player - not that I collect old cd players you understand!) that does have 1541 (have converted to non-oversampling upgraded op-amps and few bits - is quite nice, but still not right) The quest continues.....
Old 9th September 2003, 05:02 PM   #6
Banned
...that is in need of a new cdm4/19 ...
http://www.diyaudio.com/forums/showt...461#post230461
I have them in stock
Old 12th September 2003, 04:58 PM   #7
miguel2 is offline miguel2  Portugal
MY tda1543 non-os dac has invariably hum at its output, even with a copper foil as ground plane
I guess that although quite simple to build, ground IS a problem to beware of.
Miguel
Old 12th September 2003, 05:09 PM   #8
diyAudio Moderator Emeritus
jean-paul's Avatar
not that I collect old cd players you understand !
There is nothing wrong with that ! Just takes a lot of space
It's only audio
Old 12th September 2003, 05:30 PM   #9
Banned
topic collecting CD players:
what can you tell me about these:
Old 12th September 2003, 08:38 PM   #10
jean-paul's Avatar
If it's a B226 it has CDM1 and TDA1541A. Never owned one so I am not too sure. Electronically not very special and overpriced AFAIK.
I remember that some mechanical part failed more than normal but I can't recall which part
http://www.schori.info/b200s/b226s.htm
http://members.xoom.virgilio.it/hi_fi/b226.jpg
It's only audio
Wtb: Tda1543 leadbelly Swap Meet 0 19th October 2006 05:42 AM
TDA1543 dac dariusku Digital Source 3 31st March 2006 06:38 PM
Tda1543 fili Digital Source 5 25th December 2004 11:23 AM
Where to buy TDA1543 D/A stan_33 Digital Source 32 7th May 2004 07:54 AM
TDA1543 Non OS DAC jean-paul Digital Source 83 22nd January 2004 10:27 PM
Page generated in 0.11672 seconds (75.76% PHP - 24.24% MySQL) with 11 queries
