| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#61 |
Splitting hairs:
There's a difference between a "decent pc" and a fanless (with quietened hard disks) dedicated music server with network music interface. I'd have to do it well or not at all. And I fully intend to, just as soon as I can afford to! ![]() Simon
Fave. threads: Marantz CD63 | Philips CD650 | my 3-way dipoles | T-bass for dipoles | EnABL treatment | Arcam Alpha (CD) |
#62 | ||
#63 | |
Server software (slimserver) runs on almost any PC located in any room in your house (or across the web!) so PC fan noise is not an issue. Runs on Mac, Linux, and if you must, Windoze. Open source software with large community of developers. Remote control interface via web browser. My 660 CD collection fits on a single, internal 250 GB HDD all in .flac with tags and album art. An external 250 GB HDD serves as backup (and portable party/loaner music source). I use an old tablet PC as a remote control which gives me a touch screen interface and displays cover art, disc and song title, artist, year, etc. I can also use it to browse the web for lyrics, etc. Using ubuntu linux on the server PC, it has NEVER crashed in more than a year of more or less continuous operation. The CD is dead. I only hope windows will soon follow... I_F |
#64 |
I_F - that sounds like a very sensible and effective setup. This is something I need to do!
![]() Off-topic though!
#65 |
Audio Engineer
Hi, In reply to the what is changing when you make these modifications question.
What I can tell you is that the data itself is not changed, Prizm Sound did some investigation into this in the mid 90's. What they found was that the data was identical so all the 1s and 0s are correct. What changes is the way the servo reads the disk. The servo in a CD player uses current in great big gulps and with the change to digital servos about 15 years ago this got much worse. The noise the servo introduces to the PSU then interacts with the the reconstructed clock and introduces jitter on the DAC clock reconstructing the audio samples. Jitter levels of 150PS are audible. Systems with good linearity or 24bit playback even lower than this. Other things that can cuase jitter are mechnical feedback from the spinning motor to the quartz crystal generating the clock and indeed the sound field in the room vibrating the crystal. If anyone is paticullarly interested in this do a search on Julian Dunn on the web as he has done a significant amount of research into the effects of jitter and many of his papers are available free on the web. However this is extreemly technical stuff and the mathematics is complex. Regards, Andrew |
#66 |
Fascinating, thanks.
#67 |
Hi, Stumbled across a tip a few weeks ago about copying you CD's to BLACK CDR's. Bought a batch and they would not record (a littled pisses off, but those are the breaks). Then last week saw some Maxell Black CDR's so always a mug the second time around bought some more. All i can say ia WHOW & I mean WHOW. More of evrything, let's say the equivalent of doubling the cost of your H-Fi rig. Not all discs improve to the same degree but the good news is that they all do improve. Hunt them down and try it, you will not regret it.
Cheers.
tabarddn |
#68 |
I will try it, thanks
![]() Simon
| Converting CAL CL10 5 disc player to a single disc player | stoolpigeon | Digital Source | 0 | 27th May 2007 01:25 PM |
| Tweaks vs. insanity (yes, just another thread about tweaks; but there are some links) | Rodeodave | Everything Else | 7 | 28th February 2007 03:05 AM |
| Mini disc | baggins | Digital Source | 8 | 19th May 2006 12:16 AM |
| Disc Stabiliser | mrfeedback | Digital Source | 1 | 2nd October 2003 03:06 PM |
| Disc colour = darker is better | rick57 | Digital Source | 13 | 29th June 2003 08:22 PM |
| Page generated in 0.10607 seconds (79.59% PHP - 20.41% MySQL) with 11 queries |
