Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 3rd September 2003, 11:52 AM   #1
Klaus is offline Klaus  Germany
Unhappy modify D1 stage for 0.1mA DAC?
Hi freaks,
One special question, maybe you have an idea or even a solution!
I want to take advantage of the genius simple output stage principle of the Pass D1 DAC. It needs two parallel working DAC-IC´s, one inverted, with 2mA current output to be capable to do so. Just one DAC would also work - but no benefit of real symmetrical signal usage. The D1 circuit is biased to 10mA using the IRF610. So far easy, but…
My Consumer DAC uses the 1bit-DAC TDA1547 http://www.semiconductors.philips.co...1547_CNV_2.pdf . It has symmetrical voltage outputs – so no way for D1 stage. BUT (for feedback function of the internal OPA output stage) the symmetrical internal current source outputs of the switched cap network are also connected to pins. Lucky, not at all – 1V created on 13kOhm load equals just 0,07mA available output current! And the datasheet leaves unclear how an internal circuit of the current output could look like and if it would disturb.
So the first question: do you think this pins of the V-DAC could be used as current output like on "real" I-DACs?
The consequence would be to adapt Nelson´s D1 output stage to a current of just 0,1mA signal. As far as I understand this is possible by "just" changing the bias to e.g. 1mA – so increase upper R 1.5k to 15k and lower R 3.3k to 33k? So 0.07mA would cause 1V output voltage, enough for one branch. So coming to the second question: is this idea right and which FET would be appropriate and good sounding biased at just 1mA?
If all my explanations are bull sh*t and I have just shown not to be an electronics designer, do you know any really good symmetrical output stage for the V-outputs? Actually I us an OPA637 (with tricky RC-protection circuit not to oscillate) as I/U converter. Behind this just a passive RC filter with f_o~55kHz. Sounds almost perfect – but the inner silence of music achievable just by symmetrical signal transport is not given. A noisy floor disturbs a bit the joy of music, if you know, what I mean. Also even the OPA637 leaves a rest of OP sound, but small compared to standard OPA´s.
Tweaky regards and thanks for your hints!
Klaus
Old 3rd September 2003, 01:16 PM   #2
tiroth is offline tiroth  United States
Klaus,
I don't know if this will work with your DAC, but I have done some playing with the D1 stage. The bias current is not really related to the I/V functioning of the circuit, although it certainly must be high enough not to "clip" at full signal. You set the load resistor based upon how much voltage you want out for a given current. Unfortunately changing the load resistors can mean a lot of playing around with values, so you may consider CCS on these FETs...it makes the circuit a lot easier to play with. More linear too, although I know this may not be considered ideal by its designers.
Alternatively, you could always just use the BLS diff pair for voltage buffering/gain. Even if your plan works it may not sound great since the DAC IC was not designed for it. In fact I would suggest you use a simple opamp I/V stage to evaluate whether it is worth going to a more complex circuit...at least that way you won't doubt the I/V if something isn't working.
Good luck.
Old 4th September 2003, 01:29 PM   #3
Originally posted by tiroth
Klaus,
Good luck.
Thanks for your answer. Seems that no one has a clear opinion about that. Hopefully more feedback will come reflecting possible failures in thoughts…
I agree on your explanations. The D1-value of the 1,5k resistor was set by the aim to get 3V signal peak at 2mA current peak from the DAC. Then the supply voltage was set "high enough" to get a bias current "with safety" = 10mA and the required drain voltage = 17V offset for the output buffer FET. With my available TDA1547 current of just 0,07mA the 1mA of bias would principally give almost the equal situation with 15k resistor. I see no playing around – as far as I understand the circuit , after adjusting the current sink resistor (= 3.3k to -30V in D1) to 33k for 33V, the balance should by given again for 1mA. Am I right, CCS means capacity values of the FET? Of cause a very low capacity FET should be used. Do you know any proposal for an appropriate FET which works at 1mA in a point of "good sound" performance? Thanks for advice, guys! It will take just some minutes to test the circuit, so I will do.
Alternatives are difficulty – one OPA will stay, however. I will first test how the DAC internal symmetrical I/U OPAs sound driving via 100Ohm output R the cable load directly to Aleph P. Maybe they do not really need the output buffer of a second, external OPA. Or, as you proposed, external BLS could replace this external OPAs – but the sound of the internal I/U OPA is still in…
Klaus
Old 4th September 2003, 02:17 PM   #4
Default amendment CCS
Now I found what CCS means...
Of cause, if a solution would be found for my DAC and sonically wise testet positive I would go to improove the performance by CCS. Thanks for the hint!
Old 8th September 2003, 08:28 AM   #5
Hi KLaus,
I just read the other thread in which you link this thread.
Your idea to modify the D1 IV-stage for 0.1mA seems OK to me. Increase the upper resistor that actually converts I to V to get some voltage out, and adjust the lower bias resistor accordingly.
I don't know if a JFET is the optimal choise here, a BJT could maybe result in a lower input impedance. Further more, you could use Jocko's simple IVstage design so that you would need such high supply voltages.
Thijs
Old 8th September 2003, 09:29 AM   #6
Originally posted by tschrama
Hi KLaus,
Thijs
Hi Thijs,
thanks for feedback!
I anyhow need a new PSU for this output stage, the consumer DAC has just 12V available. So the high voltage of D1 design is no problem - it even gives a good feeling to have reserve...
For the output buffer stage I will go with IRF610 biased @ 10mA - to have almost everywere in my Pass chain the same sound. For the converter stage you are right, a BJT could offer benefit. I will check out.
I think first I will start with a 2SK389 test @ 1mA bias. CCS will be applied. Let´s tweak!
Klaus
Old 1st January 2004, 11:22 AM   #7
Default HAve you made it ?
Hi Klaus,
I want to upgrade my Marantz CD 16 with the 1547 inside as well. So, I would be extremly interested to understand if you succeed in combining a 1547 with Nelson's D1-stage and basiscally what the final schematic was / how you connected it to the 1547.
Thanks & Best Regards
Old 13th January 2004, 01:41 PM   #8
wuffwaff's Avatar
Blitz, Klaus,
I´m also interested in ways to improve my CD10. Not using the integrated opamps etc.
Modifiing the D1 stage for 0,1mA should be possible (be it by changing resistor values or using Klaus´s setup with CCS and 2SK389) but the problem with CD10/16 is that they use one TDA1547 per channel so 2 times +out and two times -out are available.
Any ideas how to implement these without throwing away one half of the DAC?
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 14th January 2004, 07:59 AM   #9
Hi William,
I can not see any problem?! Your device is much better – the designers spend two DAC chips to improve performance. I guess they use on one DAC just the right and on the other just the left channel. Or they paralleled somehow the two channel outputs of one DAC. By checking the layout or schematics if given you will find it out easily.
Then you do the same like I did: connect the D1 clone stage current input and ground to the appropriate pin of the DAC (by this open the external 13k I/U resistor). Two times for two channels = four D1 stages. Any supply etc. does totally not matter – the current flows out of the DAC pin and back to its ground.
You will be surprised about the sound this simple TDA1547 is performing! But you have to tweak the caps for U_ref and U_analog. Best elko (Pana FC), BG NX0,1uF bypass and Vishay MKP1837 do best job at my DAC.
Klaus
Old 14th January 2004, 10:20 AM   #10
wuffwaff's Avatar
Hi Klaus,
they use one DAC per channel together with on double opamp to change the 4 output signals (double symmetrical) to a normal symmetrical output and after that follow two further opamps for further filtering and finally a single ended output comes out.
I know that I can use 4 D1 stages but what should I do with two symmetrical outputs per channel? Not much I´m affraid.
Adding the current outputs of the DAC would be a possibility (for a total 1.4mA) but I don´t know if this can be done without damaging or changing the DAC or output signal.
william
modify my old 80s amp ECBLN Solid State 26 15th July 2010 06:33 PM
CD63 - modify or replace the analogue stage? DaveCr Digital Source 1 27th September 2005 02:04 AM
How to modify Aleph ONO to line stage preamp aht Pass Labs 2 11th January 2005 01:31 AM
Modify P3A TedPolzin Solid State 9 31st October 2002 02:17 PM
Page generated in 0.13247 seconds (83.27% PHP - 16.73% MySQL) with 11 queries
