Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 2nd September 2003, 04:41 PM   #1
MWP is offline MWP  Australia
Default Tantalum VS Electrolytic
Hi guys...
My current DAC project requires a few 10uF on the DACs for what i assume to be virtual ground decoupling.
Whats going to be better for this purpose, tantanlums or electro's?
And generally speaking, which is better suited to Audio applications (physical and capacitance size differences disregarded)?
Thanks...
Old 2nd September 2003, 06:00 PM   #2
Default Re: Tantalum VS Electrolytic
[QUOTE]Originally posted by MWP
[B]Hi guys...
Try OSCONs.
Old 2nd September 2003, 06:00 PM   #3
tiroth is offline tiroth  United States
I have had success using SMD aluminum organic polymer caps. I think the key is to minimize impedance, preferably over a broad frequency range.
Old 2nd September 2003, 06:08 PM   #4
Banned
Horowitz Hill says about Tantalums:Accuracy poor, temperature stability poor.
Also Tantalum isnīt political (or ethical) correct these days. If you need low quality and cheap use a normal eletrolytic, if you need quality use film. A very good and cheap compromise would be using the electrolytic and a small film like 1uF MKS2 in parallel.
Old 2nd September 2003, 09:05 PM   #5
Default square peg round hole
It all depends on the application.
Old 8th September 2003, 09:48 PM   #6
Send a message via AIM to jewilson
Default Tantalums or great for the right app
Yes, tantalums if you are using the correct part they or great for removing power supply switching noise, great in timing circuits and higher temps. Many of them have a much better ESR the electrolytic.
Jim W.
Old 9th September 2003, 06:52 AM   #7
Jay is offline Jay  Indonesia
So far I have the same conclusion as with Till. I had been suspecting that people use tantalums for their size and durability. It is IMO mainly the price that makes them unsuitable for many applications. For removing power supply switching noise, how about parallelling ceramics of the same price? Hehe just my imagination.
Old 9th September 2003, 02:37 PM   #8
Default Tantalum Cap For Supplies
While it's good to decouple high frequency noise with ceramics, low frequency switching noise is best done with tantalums because of there low ESR. If you analyze the electrolytic caps, they all have poorer HF performance as they increase in size.
Ok not all tantalums are created equal, that true for film, ceramic and electrolytic caps also. Also, as you pointed out not all designs can afford the real estate for electrolytic caps.
Jim W.
Polarity of tantalum - need help Nordic Parts 4 13th May 2008 06:08 AM
Tantalum Pbassred Solid State 2 25th February 2006 07:28 AM
How to ID Tantalum resistors?? JDeV Parts 12 21st September 2003 02:32 PM
tantalum rafafredd Tubes / Valves 0 8th December 2002 11:51 AM
Page generated in 0.09910 seconds (78.94% PHP - 21.06% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
