| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I'm trying to do single to dual op amp adapter ,but I think I drew something wrong.
So if someone can take a look and tell me whether it's good. How can I insert pcb and brd. file from egal her!?!? Last edited by branet; 18th September 2011 at 11:22 AM. |
#2 |
Print screen, paste in paint, save as jpeg?
#3 |
Here it is.
#4 |
It's a bit hard to read with the overlays in the way. Maybe you can turn those layers off before doing a screen capture. Or move the text out of the way, if Eagle allows that.
Another way to capture printouts is to install FinePrint. Apart from the useful ability to preview print jobs (and save paper by removing unwanted pages or combining multiple pages on one sheet), it can export them in various graphics formats. When it comes to verifying layouts, one way is to print out the schematic and the layout. Generate and print a netlist. Then take a coloured marker or pencil and mark off or trace each connection on each sheet. That's what we'd do at work before sending a PC board out to be manufactured. |
#5 |
Hi Branet
I am already doing this conversion of single adapter to be a Dual see opamp - opamp construction with pass transistors, best with 15v dual rail supply. Here is the recipe: Needed Brown Dog single adapter Better op amps ie AD825 Bc846 NPN Bc856 PNP Enammeled Wire and 2 strands of RG 58 coax outer shield Cut the track at Pin 7 Cut the track at Pin 4 Mount the Bc856 to have its emitter join to adapter pad 4, its collector join to where Pin 4 came from its base be joined by 2k4 0603 surface mount resistor to the collector Mount the bc846 to have its emitter join to pin 7, its collector join to pin 8 and its base to be joined by 2k4 0603 surface mount resistor to the collector Break Pin 1 and Pin 5 and 8 of both op amps, in this format they are not needed Join Pin 6 of op amp one to Pad 1 of adapter with enameled wire, taking care to space it away from pad 6 Join Pin 7 of op amp one to Pad 7 Op amp one, use Pin 2 and 3 and 4 normally, so solder their legs to the adapter tricky as they are up a bit higher due to transistors below the op amp Place op amp 2 above op amp 1, solder its Pin 4 and Pin 7 to op amp 1 Pin 4 and 7 - tricky solder enameled wire from Pad 5 to Pin 3 of op amp 2 solder enameled wire from Pad 6 to Pin 2 of op amp 2 Finally Solder enameled wire from Pin 6 of op amp 2 to Pad 7 of adapter. Hope this helps / Chris . . Last edited by Chris Daly; 19th September 2011 at 06:50 AM. |
#6 |
I turn off some layers!
| unbalanced single or dual channel mosfet amp input OP circuit | Msypho | Solid State | 0 | 6th July 2011 06:11 PM |
| Foster 12" Woofer Ripole sub: single dual driver unit or dual single driver units? | IG81 | Multi-Way | 3 | 4th February 2010 02:48 AM |
| Op amp current consumption - dual vs. single | speakerguy79 | Parts | 2 | 20th March 2007 10:21 PM |
| Is it the right way to bridge a dual OP amp? | Mickey | Chip Amps | 1 | 26th February 2005 11:31 AM |
| F.S.: Single Op-Amps OPA604, or trade (need dual). | Cobra2 | Swap Meet | 1 | 21st November 2004 12:46 PM |
| Page generated in 0.09724 seconds (76.64% PHP - 23.36% MySQL) with 11 queries |
