diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Digital Source (http://www.diyaudio.com/forums/digital-source/)
-   -   Cambridge Azur 540C CD-TRAY (http://www.diyaudio.com/forums/digital-source/196500-cambridge-azur-540c-cd-tray.html)
Redalen 13th September 2011 12:56 PM
I slightly touched the CD-tray when it was out. And now it's has to be psysically helped out and in. Trash!? Any idea of how I can fix this?
This was an extremely weak construction in my opinion.
Beacon64 13th September 2011 08:15 PM
Hi, the drive is a standard Sony KSS 213. You have probably knocked the tray off it's guide teeth / gears, which you can get to work again with a bit of fiddling. You might also check the belt that opens the tray, as it may have slipped off the motor, though if it tries to open, the former is most likely. Hope that helps
Resources saved on this page: MySQL 18.75%
