| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I have researched most of vintage portable cd players made by Sony, Panasonic, Philips, Denon, Aiwa, Citizen, Toshiba and Kenwood.
I will replay any technical question about the following models: Sony: D50 D50MKII D55T D100 D150 D250 D350 D303 D555 D99 D90 D3 D2 D2T D66 D34 D33 D121 Panasonic: SL-XP7 XP5 XP3 S505 S900 S700 S470 S490 Philips: CD10 AZ6808 AZ6819 AZ6826 AZ6804 AZ6805 Denon: DCP50 DCP100 DCP150 Aiwa: XP50 XP66 XP77 XP6 XP7 Citizen: CBM1000 CMD3000 Toshiba: XR-P20 P21 P22 Kenwood: DPC-80 92 R7 7 77 92 Welcome any technical question! |
#2 |
I have a Sony D-150 (US equivalent is D-15) that I adjusted carefully according to the service manual. But it is still very sensitive to shock: it skips when I knock it lightly. Someone recommended me to replace the spindle motor, what I did, but no improvement. The eye signal and the laser current is within tolerance. Is the shock sensitivity normal at this early model? My other question is the lead-acid battery BP2-EX (4V, 600mAh), is there any alternative for replacement?
#3 | |
There is a solution about your dead battery. It can be replaced by a Li-On battery, uses same battery cartridge with the original battery. Common capacity is 4.2V 1000MA. Considering to its special demension, maybe it's hard for you to find one. If more than 10 batteries are needed, I'll consider to prepare a batch for you guys. Accordingly, charger circuit should be modified and maybe your transformer will be asked to check whether it will qualify for chargering a Li-on battery. |
#4 |
Sorry if I'm stating the obvious here, but Sony players are common enough at thrift stores and yard sales that the cheapest solution may be to swap the spindle/pickup assembly from another player. If the assemblies are the same shape, they probably interchange, so you can keep a rarer model (wired remote, digital out, backlit car model, whatever) going by sacrificing a more basic model.
#5 |
Good suggestion! If they still contain some valuable components without aging.
| Is there life after (laser) death for great vintage CD players? | cdwitmer | Digital Source | 8 | 24th January 2010 01:42 PM |
| "Vintage" CD players | cscmc1 | Swap Meet | 0 | 21st June 2009 10:43 PM |
| Vintage cd players dedicated website | fishzippos | Digital Source | 6 | 9th May 2009 03:59 PM |
| Vintage Cd Players Wanted!! | aenimo | Swap Meet | 0 | 28th December 2007 12:01 AM |
| Page generated in 0.08057 seconds (76.23% PHP - 23.77% MySQL) with 10 queries |
