| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi all,
I opened up my NAD T550 DVD player today with a view to tweaking it. This is from the NAD Datasheet for the T550....... '....Unusual for DVD players, high quality Burr-Brown (OPA2134) op-amps are used instead of the much lower grade usually found........' And '.....A Burr-Brown PCM1716, normally associated with top of the range CD players. In combination with the 96/24 DAC this means you will get the best performance, regardless if you are playing back CD's, DVD's or VCD's' here (Manuals and downloads - datasheet) Great, I thought, not a bad place to start tweaking, I even read a thread on here where someone replaced that DAC with a Wolfson. It's i2s so maybe I could even tap it and replace it altogether. Anyway - I got the top off and the main PCB out, imagine my surprise when I could find no trace of the PCM1716 OR the OPA2134's!!!! It seems the DAC is actually a PCM1600 (for the 5:1) and there is a space for the PCM1716 (it's even marked on the PCB) but it isn't there! NAD imply that, when playing a CD, the decoding is done by the PCM1716 but not in this case! I understand the various merits of the op-amps and DAC's and I wasn't expecting miracles from this exercise but I feel I've been 'had by NAD' Anyone any thoughts / experience of this?? Cheers Josh |
#2 |
Ok - I definitely don't have a pcm1716 on board, or any OPA2134's despite what the NAD marketing blurb says.....grrrrr.
I do have an SCLK, LRCLK, DATAO and GND labeled solder points on the board though so I thought I'd tap into these to see if I could get i2s out. I can! I then connected these up to my TDA1543 DAC (having checked with the scope first) and I get sound! But.....it's crackly on both channels and low volume. So I think I'm getting 24bit and squeezing it into a 16bit DAC (this assumption from much googling!). My question is, can I re-sample to 16bits or am I wasting my time on this one? The goal was really to use the NAD as a transport coupled to the DAC via i2s, without having to go via spdif (I haven't got a receiver). Again, any thoughts appreciated! Cheers |
| CD player NAD 502 as DAC, is it possible ? | kanompia | Digital Source | 6 | 20th May 2011 02:27 PM |
| mash dac - nad 5000 mods ? | then_dude | Digital Source | 4 | 30th December 2009 09:59 AM |
| NAD 512 replacing DAC for one NONOS | pmonti | Digital Source | 0 | 9th March 2005 08:10 PM |
| Nad NAD C162+C172 diagram(schematics) | Bgt | Solid State | 9 | 16th January 2005 10:04 AM |
| am i missing something | theChris | Analogue Source | 1 | 22nd June 2003 12:25 PM |
| Page generated in 0.06914 seconds (72.78% PHP - 27.22% MySQL) with 10 queries |
