| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#531 |
Idss.
Patrick
xen-audio.com |
#532 |
Thanks Patrick.
#533 |
Patrick, you recommend K170BL for the 8mA IDSS, but I can only source GR at much lower IDSS (3-5mA?). Any ideas on how I can compensate for the lower IDSS?
#534 |
is choosing a less facetious title...
i'm sure someone can help you find some BL, if nobody closer can, i can probably help you out. is it the standard or sabre version you are building? in other words how many do you need?
#535 |
xen-audio.com |
#536 |
Thanks guys
#537 |
Hi Patrick,
Will the standard SEN circuit on page 1 works with TDA1545A DAC? |
#538 |
Not as is.
Someone has used it successfully for the TDA1541. Maybe you should ask him. I have no on-hand experience with those old Philips DACs. Patrick
xen-audio.com |
#539 |
Thanks for the quick reply....
#540 |
You're welcome.
Patrick
xen-audio.com |
| FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball | prooptiki | Swap Meet | 1 | 22nd May 2010 05:57 PM |
| Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A | novec | Digital Line Level | 11 | 11th May 2010 11:57 AM |
| > Audio <> music <> quick <> synergy <> angst>? | rick57 | Everything Else | 0 | 4th May 2007 04:03 PM |
| >>> cheap 50,000uF 60V capacitors here >>> | Lubomir | Swap Meet | 0 | 1st February 2007 03:36 PM |
