Zen -> Cen -> Sen, evolution of a minimalistic IV Converter - Page 53 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 21st December 2011, 08:45 PM   #521
I forgot to mention, these 2SK146 are BL grade (8-16 mA Idss according to datasheet).
Old 22nd December 2011, 03:28 AM   #522
EUVL is offline EUVL  Europe
If you make your own PCB, yes.
The pinout of the 2SK146 would have a real hard time fitting onto my PCB.
Patrick
xen-audio.com
Old 22nd December 2011, 08:38 PM   #523
Well, with so little parts, I might as well do it without PCB.
Thanks for replies.
Old 2nd January 2012, 09:36 PM   #524
Well, I've built it. The actual SEN is only one tenth of the PCB , the rest are two shunt regulators. I used two separate transformers, and I was having trouble with large amounts of hum, buzz, distorsion, etc., but that was solved after adding of 100R resistors on gates going to the ground (thanks for the tip )
I still have some "buzz" on higher volume levels, but I thing that the problem is with close proximity of transformers, I will rearrange them. It is sounding good so far, the voltage on regulators is 17.5 V, I will experiment with higher voltages, for with these transformers I can go as high as 21 V regulated.
Thanks again for everything
Old 2nd January 2012, 09:43 PM   #525
Ah, once again I forgot to write something.
This is off course only one SEN PCB made for personal use. I do not intend to "manufacture" it or anything like it. It's not even a "real" PCB actualy, I just drilled some more holes in spare space of the shunt PCB and connected the JFETs with wires
Old 3rd January 2012, 04:41 AM   #526
Yes, for such a simple circuit it is really totally viable to do P2P without a PCB.
And I would encourage anyone to try this even on a breadboard.
Suggest you now try to play with passive components, especially R_iv and C_iv.
Don't waste those FETs.
P.
xen-audio.com
Old 3rd January 2012, 04:42 AM   #527
BTW your SEN circuit is too close to the regulator for my liking.
If you were to do another PCB again, try to separate the two with 5~10mm space.
Just gut feeling, no scientific proof.
Patrick
xen-audio.com
Old 3rd January 2012, 07:14 AM   #528
qusp is offline qusp  Australia
qusp's Avatar
really? is it simply because its low level analogue? because normally the closer the better, as you well know.
Old 3rd January 2012, 09:27 AM   #529
It's because everything including the power supply is floating.
Patrick
xen-audio.com
Old 3rd January 2012, 02:27 PM   #530
Starting to look at this project again.
Please remind me: Do the SK170's need mathcing of both IDSS and VGS or just IDSS?
Ryan
FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball prooptiki Swap Meet 1 22nd May 2010 05:57 PM
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A novec Digital Line Level 11 11th May 2010 11:57 AM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 04:03 PM
&gt;&gt;&gt; cheap 50,000uF 60V capacitors here &gt;&gt;&gt; Lubomir Swap Meet 0 1st February 2007 03:36 PM
Copyright 1999-2017 diyAudio
