Zen -> Cen -> Sen, evolution of a minimalistic IV Converter - Page 27 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 21st September 2011, 05:40 PM   #261
EUVL is offline EUVL  Europe
That is not entirely true.
People seem to think that 2SK170 / 2SJ74 or 2SK389 / 2SJ109 are the only ones.
At the F5 thread, I have published curves for 2SK163 / 2SJ44.
They are true complementaries.
I do agree with the differences in capacitances.
But one can handle that in circuit design.
Patrick
Old 21st September 2011, 05:47 PM   #262
Joachim Gerhard's Avatar
I like BC550,560, sure. They have high Hfe and this is also very linear over a wide range of idle. They have some early effect though but that is not a problem with common base.
They have high Rbee though of around 130 Ohm. That is not a problem in most I/U converters i think. To lower that you can parallel them in a Faulkner arrangement. The 15mA you chose is also not the null in distortion. That happens when you run each transistor at about 5.5mA. So you could parallel 3 plus 3 BC550,560 each run on 5.5mA.
Old 21st September 2011, 05:48 PM   #263
Samoloko, when i follow your link i can not find anything like a circuit schematic.
Old 21st September 2011, 05:52 PM   #264
I know next to nothing about BJTs.
Could you explain or link to some references ?
Or suggest another BJT for 15mA bias ?
Patrick
Old 21st September 2011, 05:54 PM   #265
It links you to post #104 where there is a schematics in spice next to the noise simulation results.
On the left.
Patrick
Old 21st September 2011, 06:41 PM   #266
Calvin is offline Calvin  Germany
Calvin's Avatar
Patrick, I certainly won´t put my veto in for Your circuit in #238. Anybody should feel free to evaluate this not so young circuit.
I do doubt though that it is easy practicable circuit. The double current mirrors are prone to oscillation and need very tight tolerated/matched parts. I´d rather prefer the simple structure with caps, that promises stable working and easier success.
The offset of the bipolar CEN is very low already. It might present a problem with direct coupled MC pickups but not with DACs. The voltage compliance of DACs allows app. +-1V. In BB/TI-DACs this voltage is limited to the Vf of the protection diodes. As long as the voltage swing at the CENs input remain below a couple of dozens of mV there´s no influence on the DACs THD figures.
As Joachim already told, the BCs run well on low idle currents around 5mA. current gain and saturation voltage raise above ~10mA of collector current. For higher currents the Zetex ZTX650, ZTX689, ZTX690 etc. and their complements might be interesting.
jauu
Calvin
Old 21st September 2011, 06:45 PM   #267
bcarso is offline bcarso  United States
Patrick
What/where is the "F5 thread"?
Brad
Old 21st September 2011, 06:57 PM   #268
heinz1 is offline heinz1  Europe
Brad
F5 power amplifier
Old 21st September 2011, 07:19 PM   #269
EUVL, cancelation of distortion in BJT´s is best when they run on 2/3 Gm theoretically.
That is as far as i remember for third order intermodulation. Other bias conditions can cancel other order distortion so it is a bit complicated. BJT´s in general profit more from degeneration then Fets. When you degenerate Fets too much they develop a complex spectrum. This is different in BJts. See the PDF. This is about BJT´s.
Old 21st September 2011, 07:21 PM   #270
Originally Posted by heinz1 View Post
Thanks! It did sound vaguely familiar, but I hadn't been around here for years until running across this thread via Google.
FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball prooptiki Swap Meet 1 22nd May 2010 06:57 PM
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A novec Digital Line Level 11 11th May 2010 12:57 PM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 05:03 PM
&gt;&gt;&gt; cheap 50,000uF 60V capacitors here &gt;&gt;&gt; Lubomir Swap Meet 0 1st February 2007 04:36 PM
Copyright ©1999-2017 diyAudio
